Question about Panasonic Lumix DMC-FZ7 Digital Camera
Camera will not power on
I have not used my camera since may. my battery and charger was misplaced. I borrowed a battery and charger from a friend with the exact same camera. i charged it until the green light stopped. Replaced the battery into the camera and the camera will not turn on. 3 months ago i had no luck powering it on grom an ac adapter, and tried the pc connector to see if with that I could get power to download my memory card. no luck. What is happening? help!
  • 790 Answers
Ok you have to check the bettery terminal and the power switch, maybe you have lost contact in your unit.
Posted on Oct 09, 2007
Replaced battery since it wasn't holding a charge. Has been plugged in for 24 hrs, still won't power on when unplugged from wall charger. What course of action should I attempt?
Possibly the charger itself is bad and only operating as a electrical connection/power cord for your camera. Try borrowing or buying another charger or take the camera to a local camera repair center or Best Buy, etc or contact customer service for your camera's manufacturer.
Hope this helps. Mike
May 24, 2015 | Kodak Easyshare M580 Digital Camera
Telecom r100 battery
It could be one of these three things.
1. Bad port. Often in laptops these ports become loose.
2. Bad battery.
3. Bad charger.
Borrowing either a universal power charger, or the charger from someone with a similar laptop, can eliminate some of the possibilities unless it is indeed your charging port.
If after plugging it in, the battery charges you know you had a bad charger. If the battery fails to charge, you know its time for a new battery. Again this only if the port itself is not bad.
Universal chargers can be expensive. You can find batteries and chargers on Ebay for a decent price.
Mar 01, 2014 | Dell Computers & Internet
Camera not charging with charger
It's unlikely that the charger burned out from being connected to the camera with no battery.
Try taking the battery out of the camera again, and carefully putting it in, again. Make sure the camera will turn on, to check that the battery is well seated.
Then connect the proper charger. If there are still no lights, try plugging the charger into a different outlet that you know is good. If it still doesn't work, it's probably bad. If you must have a camera tomorrow, start calling friends to ask if you can borrow theirs. You can get another charger later.
If you have a tech-oriented friend with a voltmeter, they can help you more...
thanks.
Apr 06, 2011 | Olympus SP800UZ Digital Camera
Plug charger in and will not charge the fan on the charger quits running in a few seconds it will beep with charger pluged in and when you unhook charger it clicks like a dead battery i wonder if charger...
David Are you leaving the power on while you are charging the Chair? If you are try charging with power off at the joystick. The manufacturers of all power batteries do not recommend charging with automotive chargers. I would try to locate a friend or neighbor that also has a chair or scooter and borrowing their charger for a few hours to see if it will charge your chair. If not contact your provider and borrow a charger from them. If the different charger works then yours is bad. You shoud be able to order a charger through your provider or by calling Pride Mobility @ 1-800-800-8586 Hope this helps you PS I didn't say you couldn't use the "other" charger. But I wouldn't want you to think I approved of it
Oct 02, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Why i charge the baterry(GP2700) whole night when i snap the picture only 2 picture can use.many times already not only gp rechargeable baterry but (panasonic 2700) also.can someone solve my problem
If you have a friend who uses the same battery try one of yours in their camera to see if it works properly. Alternatively, try the opposite and borrow a known good battery from a friend and try it in your camera.
You either have a major problem in your camera, a coincidence of two dead batteries or a broken charger. Make sure all you connections are clean. Just a simple piece of printer paper rubbed over the battery contacts is enough to clean them. Ensure the charger connections are clean and even the connections in the camera. Check the lights on your charger. Is there any indication the battery is flat to start with and any indication of when it's charged? Usually a red light means the battery is charging and that light going out or turning green means it's charged. The battery shouldn't have to be on all night. Usually it should take maybe an hour or 2.
Finally, how long have you had your batteries and are they Li Ion or NIMH. Nicads are no good for digital cameras. They can develop memory problems. So if they are Li-ion or Nimh ensure you are using the correct type charger for those batteries
Apr 14, 2010 | Kodak EasyShare C653 Digital Camera
My blackberry 8520 turn off
try these steps.
1.. borrow same battery from a friend and insert it to your phone and switch on.
2. borrow same type of charger and charge your phone and wait to check.
3. else, try, inserting your battery to your friend's phone and check if her phone will power on, but be sure to let him know of your problem, so she or he may be aware of it. , hence, just do step 1 and 2,
4. go to your nearest service center and have them check your phone.
Feb 21, 2010 | RIM BlackBerry Curve 8310 Smartphone
DCR-SR42 Camcorder does not power up
I think AC power charger of your camera got defective first and later on battery lost its charge so no power for camera now to power up.
Try to borrow same charged battery from friend. neighbors etc and test your camera.
If camera power up, it is sure that charger has gone and you need new one.
let me know in that case to guide you further.
Oct 05, 2008 | Sony Handycam DCR-SR42 Camcorder
Camera wont turn on **** battery is charged
My Ixus 960 IS will not turn on even with both batteries fully charged. Any suggestion as it looks like a common fault?
Regards
Moooch
Jun 23, 2008 | Canon IXUS 960 IS Digital Camera
BATTERY dead. how to charge?
The battery is removable and the camera came with a charger that you connect the battery to and plug into a household socket.
Mar 16, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Panasonic Lumix DMC-FZ7 Digital Camera Logo
169 people viewed this question
Top Panasonic Cameras Experts
Computer Links
ogerfire
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
