Question about NEC MobilePro 770
NEC MobilePro 770
Bought a "new" 770 off of ebay. It is in pristine condition ... original box, unsent warentee card and all the documentation. Wouldn't power up. Charged the battery for 10 hours and did a hard reset. It came on and worked perfectly for about 19 minutes, It shut down and won't come back up. Did another hard reset. No good. Is it the battery, the internal battery or do I need to send it in to have it repaired. It is just like new and I think it is probably something simple but I am no tech genius.
These are older devices, and Lihium-Ion batteries degrade from the date of manufacture. You will most likely need to follow instructions (easy to find on the internet) to "fix" the battery. It needs two new cells.
Posted on Oct 25, 2007
Wireless internet on NEC mobilepro 770?
dail up or get the serial port cable and run through another pc just a heads up mine has pocket internet explorer and most web pages won't load right.
Feb 28, 2009 | NEC MobilePro 770
Getting the wirelss to work
it needs to be 16 bit and 802.11b wifi card to work
Jun 03, 2008 | NEC MobilePro 770
Memory card
I use a 6 in 1 scandisk universal adapter that accepts SD and other storage cards. They can be purchased off the internet for about $30.00.
I put in my 1 & 2 gig cards and it works fine
Nov 29, 2007 | NEC MobilePro 770
Connection problems
Attach the AC power cord or adjust the power saving mode so the unit does not go into "standby" mode. This is caused by the unit going into "standby" mode when data is being transferred.
Sep 15, 2005 | NEC MobilePro 770
Lower fidelity voice recording capability
MobilePro 770 units with a serial number before MC-B004P3US-033 may have a lower fidelity voice recording capability. This may cause voice recognition software to not function properly. This issue is not experienced with new units.
My MobilePro 770 intermittently stop responding at startup
With the Owner information screen or passwords enabled, it is possible that a deadlock condition can occur as the Graphics, Windowing, and Events Subsystem starts up. The only work around at this time is to disable the owner information screen in Settings/Control Panel/Owner and/or to disable Passwords in Settings/Control Panel/Passwords. This information is also found at Microsoft site at: http://www.microsoft.com/technet/ Article ID: Q260315
Update files be installed
The MobilePro 770/800 update files should be installed in the following order: 1. MP77_UPDATE 2. CE_SP1 3. SCHANNEL.DLL Memory usage: The three patches use approximately 2,155 KB of storage and 418 KB of program memory. Patch Storage memory Program memory None (hard reset) 323 KB 1,435 KB MP77_UPDATE 1,016 KB 1,784 KB CE_SP1 2,380 KB 1,895 KB Schannel.DLL 2,478 KB 1,917 KB Available (free) 13,874 KB 14,436 KB
Sep 15, 2005 | NEC MobilePro 800
UPDATE.CAB
NEC Computers has developed this update file to address several service issues with MobilePro 770 and 800 handheld personal computers. To assure proper operation, NEC Computers strongly recommends that you update your MobilePro 770 and 800 systems immediately by installing this file according to the installation instructions. * Download MP77_Update.CAB for MobilePro 770 and 800:ftp://ftp.neccomp.com/pub/Catalog/4058/MP77_Update.asp * View Installation Instructions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#Installation * See Contents of MP77_Update.CAB: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#Contents * Read Additional Frequently Asked Questions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#FAQ Installation Instructions for MP77_UPDATE.CAB for MobilePro 770 and 800 First, download MP77_UPDATE.CAB to either your HOST or MobilePro system. It must be manually loaded onto your MobilePro by either using a dial up connection, PCMCIA Flash card, or from a connected PC before continuing with the installation. To install the MP77_UPDATE.CAB file, follow these steps: Note: An out of memory error message will be displayed if you attempt to install this file twice. 1. Back up your MobilePro data and configuration using the Microsoft ActiveSync backup procedure. For details on using ActiveSync, see your MobilePro User's Guide. 2. Perform a Soft reset on your MobilePro. Note: Performing a Soft reset does not erase your data. It simply cleans up the memory and refreshes the system registry. 3. Copy the MP77_UPDATE.CAB file to you MobilePro desktop. 4. Install the file by double tapping the MP77_UPDATE ICON with your stylus. For proper installation, you MUST accept the default location - \Program Files, by clicking OK. 5. Perform a Soft reset on your MobilePro. 6. Once the update file is installed, NECC recommends that you use the ActiveSync backup procedure to again back-up your system. This time your backup will include the update file so you can restore both your data and the update file should either ever be erased. Contents of MP77_UPDATE.CAB for MobilePro 770 and 800 This file installs updates to the following built-in MobilePro drivers: * StartUI: This driver eliminates a memory leak that reduces user resources. * Bitmap files: Replaces an incorrectly sized bitmap file that can cause the unit to lock up if either "the power on password" or "Display Owner Notes features" are enabled for use. NOTE: NEC Computers strongly recommends that you update your MobilePro 770 and 800 systems immediately by installing MP77_UPDATE.CAB according to the following instructions. NOTE: During Installation of this file, you must accept the default installation directory or the updates will not be effective! For assistance or further
UPDATE.CAB
NEC Computers has developed this update file to address several service issues with MobilePro 770 and 800 handheld personal computers. To assure proper operation, NEC Computers strongly recommends that you update your MobilePro 770 and 800 systems immediately by installing this file according to the installation instructions. * Download MP77_Update.CAB for MobilePro 770 and 800: ftp://ftp.neccomp.com/pub/Catalog/4058/MP77_Update.asp * View Installation Instructions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#Installation * See Contents of MP77_Update.CAB: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#Contents * Read Additional Frequently Asked Questions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001313#FAQ Installation Instructions for MP77_UPDATE.CAB for MobilePro 770 and 800 First, download MP77_UPDATE.CAB to either your HOST or MobilePro system. It must be manually loaded onto your MobilePro by either using a dial up connection, PCMCIA Flash card, or from a connected PC before continuing with the installation. To install the MP77_UPDATE.CAB file, follow these steps: Note: An out of memory error message will be displayed if you attempt to install this file twice. 1. Back up your MobilePro data and configuration using the Microsoft ActiveSync backup procedure. For details on using ActiveSync, see your MobilePro User's Guide. 2. Perform a Soft reset on your MobilePro. Note: Performing a Soft reset does not erase your data. It simply cleans up the memory and refreshes the system registry. 3. Copy the MP77_UPDATE.CAB file to you MobilePro desktop. 4. Install the file by double tapping the MP77_UPDATE ICON with your stylus. For proper installation, you MUST accept the default location - \Program Files, by clicking OK. 5. Perform a Soft reset on your MobilePro. 6. Once the update file is installed, NECC recommends that you use the ActiveSync backup procedure to again back-up your system. This time your backup will include the update file so you can restore both your data and the update file should either ever be erased. Contents of MP77_UPDATE.CAB for MobilePro 770 and 800 This file installs updates to the following built-in MobilePro drivers: * StartUI: This driver eliminates a memory leak that reduces user resources. * Bitmap files: Replaces an incorrectly sized bitmap file that can cause the unit to lock up if either "the power on password" or "Display Owner Notes features" are enabled for use. NOTE: NEC Computers strongly recommends that you update your MobilePro 770 and 800 systems immediately by installing MP77_UPDATE.CAB according to the following instructions. NOTE: During Installation of this file, you must accept the default installation directory or the updates will not be effective! For assistance or further
NEC MobilePro 770 Logo
134 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
