This can happen when there is two problems.. One the computer might have been affected by virus.. Or the other thing might be the OS corrupted.. Try to get into safe mode and check if the system is working fine.. If it works well there try to do a system restore to a place wr it was working well.. If in safe mode also it doesnt work well then go ahead and reinstall the OS...
if a blue screen pops up with white writing theres something seriously wrong with your laptop a blue screen on a computer is the worst possible thing that could happen apart from the thing actually exploding and can be caused by a wide range of things, my suggestion would be to reinstall windows as it will basically give you brand new computer with no errors
When the computer first boots up, press the F8 key when the eMachines logo is replaced by the first Microsoft screen, then select Safe Mode from the list. If the computer will not boot in Safe Mode, you will need to boot from your Windows CD and select the repair installation option. If you can boot in Safe Mode, you will need to find out what is causing the system to reboot during startup. With the msconfig utility, disable all unnecessary startup programs and services, then try restarting the computer normally. If this works, you need to use the msconfig utility to add the startup programs and services back one-by-one until it fails to boot again (to locate your troublemaker). Keep repeating this until all services and programs (except the one causing the problem) are back in the lineup.
Press F8 while booting but before it goes into SAFE mode select "Temporarily disable restart." Now you should be able to read the Blue Screen. If this doesn't work it's likely you have the GenericFX virus and you'll need to repair the operating system.
Boot into safe mode by tapping the F8 key on startup, once you're in safe mode, run the system restore tool (usually in start -> program files -> accessories -> system tools -> system restore) to a few days earlier and restore. After that, install an Anti-virus application, such as AVG Anti-Virus, and scan your computer to remove the problems.
blue screens at system startup usally indicate virus infections or driver conflicts of hardware newly installed hardware . i have suffered many even safe mode dosent work . u first try to repair installation then if it dosent work a system formatting is inevitable
Bizarre problem description. Try disabling your laptop's wireless function and see if it works properly in that room, and let me know.
