Hi. I have a wall unit less than 5 years old. Fan is making noise. Expert told me to oil it. 1. If I dont oil it will it get damaged or is it just a convenience for the noise sake. 2. Does it make sense that such a young AC would need oiling? 3. I have another wall unit 22000 Fridgidaire that is young and ices up a lot. I had insulation pumped in to my walls a few years back. can you see any connection?
1 and 2 there two type of motor 1 has lubricating acces this youshould lubicate the other no noacces. but commonly if you lubricate and still noisy you change the bearings qty2 or sleeves qty2
2- common cause of ice
- thermostat on min setting
- thermostat defective
-air filter is very dirty
-evaporator is cloged no air pass throu
- loss of freon ( a/c is leaking)
I have an Amana Gas Fired Furnace Model CCA24FCC. It recently started blowing cold air out of the...
(More)
I have an Amana Gas Fired Furnace Model CCA24FCC. It recently started blowing cold air out of the vent registers in the house and would then shut off after a call for heat at the thermostat with the setting on Auto. In the ON setting the circulator fan just blows ambient temp air. Upon further investigation I found I have a blinking LED. It blinks three times. The manual says- pressure switch circuit not closed. That is the case because the induced draft blower is not spinning. When a call for heat occurs this fan should spin. The pressure switch is functioning- with the furnace off or not operational the switch has no continuity across its terminals. When I pull a slight vacuum on the switch, I can hear it move and then my ohmeter has continuity across it. The problem is the draft motor wont run. When the furnace is switched on or a call for heat occurs, I do not have any voltage at the induced draft blower motor terminals nor do I have voltage at the control unit terminals. Am I on the right track to replacing the control unit? By the way, I had skipped replacing my filters for a few months and they were really dirty when I replaced them today while diagnosing the furnace.
Hello My AC is posting an E2 and F5 error. It seems to turn on and of and sometimes the timer light...
(More)
Hello My AC is posting an E2 and F5 error. It seems to turn on and of and sometimes the timer light is on. I am not able to turn the AC on. Thx
We are getting an error message on our Friedrich AC (model SS10J10R-1) unit that reads either F5 or...
(More)
We are getting an error message on our Friedrich AC (model SS10J10R-1) unit that reads either F5 or E2. What could be causing this? Thx
E2 or an F5 error. Can't get the air conditioner to turn on and the timer light is on and won't turn off.
The side curtains that come with this air conditioner will fit a 36 inch window. I have windows that...
(More)
The side curtains that come with this air conditioner will fit a 36 inch window. I have windows that 38 inches. Are larger side curtains available for this model?
