Question about Philips 50P8341 50" Rear Projection Television
Problem with philips 50p8341 big screen tv
Turns on for about 20 seconds and shuts off, any ideas or common problems? got television for free just curious if worth fixing, familiar with electronics, if anyone know where to get schematics? thanks
  • 790 Answers
If in 20 seconds maybe you have lost contact at the main board hot side section!
Posted on Oct 03, 2007
I have a rca d52w23 while i was watching tv in shut off and there was like a smoke smell I mean I turn it on and it shuts off by it self is it worth fixing it and what can cause this problem
Where there is smoke something burned--unplug set for safety and if curious open rear cover and look at boards near rear of set for a burnt part--that will usually determine if worth fixing or not.
Apr 26, 2012 | RCA D52W23 52" HDTV CRT TV
Tv does'nt Pwr up
will need to be taken apart to figure problem. check fuses and for any burned component. possibly if no high voltage.. not worth fixing.
Oct 05, 2008 | Mitsubishi VS-5043 50" Rear Projection...
I turn on the tv and i get a blue screen for 5 seconds and the tv shuts off. Any ideas?
Hey bbendure, I have a similar/same same problem! My model is a GV42L.
It has a blue screen that says no signal t, then it turns itself off in about 20 seconds.
Is this the same problem you see?
Oct 09, 2010 | Vizio GV42L 42 in. LCD Television
Green Screen, No Sound, Shuts off after 10 seconds
Almost certainly the green picture tube is shorted. This is a very expensive repair; probably not worth doing.
Apr 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV shuts off while watching.
if its worth fixing?compare the cost for repairs and a new one.
Sep 28, 2008 | Mitsubishi CS-40503 TV
I have a panasonic dimension 4 turbo bake microwave model nn-a774sbbpq when switching on it runs for approx. 20 seconds and shuts off this time factor is always the same any ideas?
The uPC system is sensing a failure of some type. This could be that the magnetron is not emitting to specificaitions, or one of the power supplies are not operating in specs.
This is not something you can fix yourself. You will have to take the microwave oven to a service center to have an estimate for repair. If the unit is out of warranty, it may not be worth to service.
In case you get curious, I would never suggest for you to open the encosure of a microwave oven. There are very serious safety issues with working in this type of appliance.
Jerry G.
Sep 02, 2008 | Panasonic Microwave Ovens
Philips 46pp9302 about 5-6 yrs old after 20-30 min. shuts off
Just posted this elsewhere:
Is the cooling fan running?
If not, the set may be designed to shut down after a few seconds to protect itself (and you).
Aug 10, 2008 | Philips 46PP9302 46" Rear Projection...
My ws-55908 just turned off the other day and does not turn back on.
the main power supply has gone out it may not be worth the 4to5 hundred to repair it
Jun 21, 2008 | Mitsubishi WS-55908 55" Rear Projection...
Sony KV 20S40 20" tv flutters, reduces in size and then shuts off
The set most probably has cracked solder joints in one of the deflection circuits, which is pretty common. The picture tube and major components are fine. A good tech can quickly resolder the main board and that should not cost too much. If your set came into my shop I would charge about $50 but ask around, the shops in your area will vary.
Jul 31, 2007 | Sony KV-20S40 20" TV
TV does not turn on
You have a short in your unit somewhere or a high voltage problem. The most common problem would be a high voltage failure. If you are not familiar with televisions and their safety this is best left to a repair shop. There is not much in a TV that consumers, unfamiliar with the system, can check. The problem should not cost too much to fix. Check for a shop which has a free estimate or low estimate which will be subtracted from the cost of the repair if you choose to have the unit repaired there. Good luck.
Jul 12, 2006 | Panasonic CT-27HL14 27" TV
Philips 50P8341 50" Rear Projection Television Logo
111 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
