Question about Efficient Networks SpeedStream 3510 (936-3510-001) Networking Switch
Can't detect network
Hi, I've just bought a Toshiba laptop (Satellite) and am trying to connect to the wireless in my house. Both my housemates are able to connect to the network, my laptop is able to detect and connect to the network at uni, but it's unable to even detect the SpeedStream network in my house. Tried everything from manually entering the network to calling a couple of different IT specialists - no one seems to know what the problem is and noone knows what I should do next!!
  • kimslater Apr 22, 2008
    am trying to install telstra wifi on my satellite toshiba lap top ( this is second wifi modem - first is work) telstra big pond installation cd doesn't recognise lap top's wifi. will connect via ethrnet. am pulling hair out ! think soltuion must be simple but can't find it. telstra not much help
Hi, Thanks for your help, after a week of spending hours on the phone to BigPond, Toshiba and Siemans, and talking with other IT specialists, none of who were able to figure out what the problem was, one helpful person finally directed me to: the modem's online manual! I was soon able to set it up myself, and it is now working. Experiencing emotions somewhere between frustration, relief and disbelief :)
Posted on Oct 05, 2007
    Brigadier General:
  • 6,966 Answers
Hi, Some models of Toshiba Laptops have a slide switch either on the side or front to physically activate the built-in Wifi. Some models also will not work with some models of Access Points if using the built-in Windows Wireless Configuration Utility. A workaround is to install the Wireless Configuration Utility of the WiFi manufacturer. If your Toshiba is using the Atheros WiFi chipset, you may need to install the Atheros 802.11a/b/g Wifi Client utility to use rather than than that pf Windows. The file name is atheros_wpa_client.exe and you can just Google it. Hope this be of some help. Post back how things stand or should you need additional information. Good luck and kind regards.
Posted on Oct 03, 2007
SOURCE:
Cannot stay connected on wireless networks. Troubleshooter shows problem detected with wireless network adapter and a cable unplugged. I am running a toshiba satellite L505d with a realtek RTL8187SE...
Hi, Please make sure that you have turned on the wireless switch on your laptop because this is a message that usually appears if the wireless on the laptop is disabled.Also please update the wireless drivers for your laptop from the Toshiba website. Thank you for your time and best wishes for your effort.
Jan 08, 2011 | Toshiba (PA3212U) Wireless Adapter
How do I connect to a wireless network?
Try these easy steps :
1. Turn ON the wireless switch on your laptop.
2. Switch On the wireless router modem.
3. System will automatically detect the network.
4. If not, search for the network through Start -> Connet To (You can refresh the list)!
if it helps tell me...tc! :)
Jan 02, 2010 | Toshiba Satellite 4100XDVD PC Notebook
Problem with Toshiba wireless conection
If you have your router set-up with security enabled, you should try to re-set the router and then go back onto the routers "control panel" and re-setup the security. You can find out the correct way to reset the router and the correct address to enter into the browser to access the routers control panel by going to the router makers website and checking under Support
Feb 20, 2009 | Toshiba Satellite M45-S331 Notebook
Toshiba Satellite wireless switch doesn't turn on
Ok, if your using Vista, what i want you to do is right click "computer" select "manage" and then "device manager", then click on the + sign next to "network adapters" and right click on the wireless network and "un-install" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again
keep me informed please and thanks for using Fixya
Feb 13, 2009 | Toshiba Satellite M35X-S161 Notebook
Wireless network undetected and problem with wireless lan
first check for whether the wireless switch on laptop is turned on or not u have to keep it turned on .further install the drivers for wireless lan
Nov 21, 2008 | Toshiba Satellite A100-S8111TD Notebook
Reinsalled windows xp on toshiba notebook -- now wireless won't work.
Hi Matt,
When you try to connect wirelessly to your network did get any pop up message like asking you for a network key WPA/WEP? if your wireless network is security enabled then you need to enter the security settings again on the computer since you re-installed XP the security settings that was saved previously was also wiped out.
May I know the exact model number of wireless router/access point that your trying to connect your laptop so that I can provide you with instructions on how to retrieve the security key.
Nov 06, 2008 | Toshiba Satellite A45-S151 Notebook
Wifi problem with Toshiba laptop
you may need to enable that wireless through control panel
Oct 09, 2008 | Toshiba Satellite A135-S2276 Notebook
Wireless connection for toshiba satellite A135-S4527 laptop
Hi, there are few steps to allow the wireless network to get connected to the internet.follow these steps
  1. Verify that the Wireless hardware is working (Right click the My computer icon then goto properties then hardware tab and device manager.see the network adpater is corrctly installed.
  2. Then you can check the ip address in the ethernet properties.
  3. Then check the DNS server is connected
if it is not working , i have one web site here you can see the settings and devices to connect.
http://www1.umn.edu/adcs/network/wirelessxp.html
try it and inform to fixya.com
Apr 19, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba laptop wont find router
Right click on the network icon in your task bar or in network connections in control panel and click view wireless networks, then when all the networks show, delete them all and close the window, next, a pop up will say found wireless connections click the pop up icon again and look for your connection in the list and click connect and enter the pass phrase Iif you have security enabled.
Nov 06, 2007 | Toshiba Satellite A105 Notebook
Open Questions:
Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]Avast toll toll pHoNe {@}{\1888499-5520]
Oct 15, 2019 | Computers & Internet
See all Efficient Networks SpeedStream 3510 (936-3510-001) Questions
Efficient Networks SpeedStream 3510 (936-3510-001) Networking Switch Logo
391 people viewed this question
Top Efficient Networks Computers & Internet Experts
pongta rajkumar
pongta rajkumar
Jeffrey Groves
Jeffrey Groves
Duncan Mutch
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
