Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Hotpoint fdw 85
What is error code al 05 instructions suggest blocked filter hotpoint web site says pressure switch needs reset if thhe latter how do i do this
  • 869 Answers
This is going to keep breaking down,Call the manufacturer and demand a refund.
Posted on May 23, 2008
Hotpoint aquarius fault code f 05
  • F05 - Pressure switch jammed on full
  • Thing to do check pump is not blocked and clear it then reset machine by unplugging for 5 mins and plug back in if still gets error F 05 then you need a repair call out. hope this helps.
Jan 08, 2012 | Hotpoint Washing Machines
My washer hotpoint wt741 is flashing up f05 and wont rinse water out
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Try this out:
Small panel at rear of machine reveals the pump,
Pull of the two pipes (Plastic clips hard to get off, Slide them sideways),
Remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left,
Pump can then easily be cleaned.
Mar 06, 2010 | Hotpoint Washing Machines
Error Code F-05
Error code F05 denotes pressure switch jammed on full.
Remove lower rear cover of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit back and test.
Please rate my solution.
Thgankyou.
Feb 04, 2010 | Hotpoint Ultima WF860 Front Load Washer
Error code F-05 showing on my Hotpoint ultima
Error code F02 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose from bottom of drum.
Remove hose on to pump and check for blockage or obstruction here as well.
Pleas rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WD72 Front Load...
Hi I have a hotpoint washing machine model wt761 and it has stopped working, it will not drain. The display is showing an error code F-05. Can you help me please.
You have a blockage not allowing the drum to empty.
Check for blockages via the pump filter and the hoses
F05 means blocked pressure switch
If it still won't work come back to me
Oct 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
WD865 Hotpoint - F-05 error
F05 means that the pressure switch is jammed on full.
You need to check the pump is pumping out o/k, and if there is a filter, check and clean.
Jan 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
On my washer screen it says F-05
Error code F05 is indicating that the pressure switch is jammed on full, this could be caused by the switch itself being faulty, the water not draining out properly, or the pump not working.
Check pump and clean filter
If still does not work, then I suggest you call an engineer.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
My washer is saying F-05
Error code F05 is indicating that the pressure switch is jammed on full.
Make sure pump is working o/k and that washer is draining properly. Check filter.
If after doing all these checks and error reappears, then I would suggest you call an engineer.
Thanks
Hotpoint FDW 85 Dishwasher
You just need to switch the machine off for approx 30 seconds from the mains and switch it back on again!!
AL99 means that there is a communication error within the machines software.
Jun 15, 2008 | Hotpoint 24 in. FDW60 Free-standing...
FDW 60 Float and Filter Clean problem
Blockage in internal pipework causing water not to circulate fast enough to stop switch activating. Regards Advisor
Aug 17, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
494 people viewed this question
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
