NEC Multisync LCD 2080UX has a strip that appears after 20 mins use. Starts with flickering then turns into a solid bar. Is this a capacitor issue or other? Can it be fixed. I'm pretty handy with a soldering iron... Interestingly if the window is open and the back of the monitor is cold it doesn't happen... If you turn it off for 10 mins and back on you get another 10 or so minutes of normal use before it reappears
SOURCE: LCD Monitor power problems
yes the monitor is over heating there should be warranty on the montor
SOURCE: My NEC Multisync LCD 2080ux + has developed a weak
One thing that will affect how clear the display is if the monitors resolution is set to the wrong value. your monitor must be set at at its native resolution of 1600x1200. Any other value will result in a degraded display.
