Question about Siemens C75 Cell Phone
Siemens CF75 cellular phone problem
Hi, My phone got wet in the rain one day. I dried the battery and it was working fine.But now the display has a big spot of shadow type(its black in colour).Is there a solution to this problem. Regards Sai
My phone has a problem of sticking to one posistion it does not witch off when it is in this state and at times the screen goes black while it is on to restore this by removing the battery
Posted on Jun 03, 2008
    Brigadier General:
  • 7,752 Answers
You have to take the phone to a repair center and have the LCD replaced.
Posted on Jan 20, 2008
SOURCE:
Lock code network
HI if you want to unlock your siemens CF75 mobile from network lock ..Then have a look at sites like WickedUnlock.com here they are rendering unlock code for all mobile models at reliable cost ..You first verify that whether they are rendering code for your country and network provider .If yes then pay for it and unlock your phone ..
Dec 12, 2013 | Siemens CF75 Cell Phone GSM Unlocked
Got n95 wet didn't drop it in water just in my pocket in heavy rain, it did work but stopped about 15 min later and now 24hrs later it turns on appears to have a backlight but blank screen what can i do?
Dear user,
Immediately put if off, remove the sim and battery, removable panels if any and keep it for drying preferably in an area with +35 C temperatures but not too hot also.
This should have been done when it got wet itself, but still try this out.
If it does not work fine after doing this then you need to send it for repairs.
May 03, 2011 | Nokia N95 Cellular Phone
My LG GM 200 mobile display got wet in rain .i kept that display completely dry. after i fixed that it is not working just appears white. tell me how to solve this problem?
my LG GM 200 mobile display got wet in rain .i kept that display completely dry. after i fixed that it is not working just appears white. tell me how to solve this problem?
Nov 24, 2010 | LG GM200 Cell Phone
I was running in the rain and when I tryed to chrage it it didnt
I dropped my at&t phone in the lake a while back, I took the battery off and stuck onthe dash of my vehicle to allow the sun to bake the phone for a day or two. It still works to this day. Do not try to power up wet electronics, that's what burns thtme up. give a good drying before ever trying to charge. After a good drying you might try a new battery if drying fails. Good luck.
Oct 24, 2009 | AT&T Cell Phones
Phone got wet.
Most likely the screen display had a shortcut. You need to replace it, although it's not cheap. Expect to pay a little less than the full price of the phone.
Next time spend more time drying the phone, you can even use a bowl with rice to immerse the phone and leave it dry for one full day.
Sep 04, 2009 | LG Shine CU720 Cellular Phone
Got wet , switched off. now after drying after
Hi buddy,
First of all check wheather ur battery is affected or not otherwise it will be dangerous for u. then open the mobile then clean the hardware then charge it.
Maybe this can help u
Jul 30, 2009 | Nokia N72 Cellular Phone
Phone got wet & works fine but says network error
Cell phones do not recover gracefully from getting wet internally. The electronics were not made to get wet.
You would be better served to get a new phone. Getting a cell phone wet is almost alway death to the electronics, even if the phone is dried out completely, The problems caused by the damp electronics will cause strange and intermittent problems.
Jul 14, 2009 | Samsung Glyde SCH-u940 Cellular Phone
Wet phone
Did you try taking out the battery and letting it dry. Depending on how wet it got, your battery may need to dry out or the phone is damaged. My friend dropped his in the shower, took 2 days for the battery to dry out and it was fine.
Mar 19, 2008 | Samsung SCH-u740 Cellular Phone
Phone not working Due to to rain
This phone is very slim. Unlike other models you can't simply un-snap the front bezel from the back with out a special tool or knowledge. I assume it got wet. Try this: Remove the battery. Wipe it dry and set it aside. Then with the "battery compartment" facing down and holding the phone very firmly (don't drop it), shake the phone downward with very quick snaps get as much water out of it as you can. Then set the phone somewhere in the sun where it will not get wet again and let the phone dry out. But be careful not to let the phone get too hot. You may have to shake it a couple of more times during the "drying" to get all the water out. It may take up to an hour to dry out. After all this if you still have a problem then take it to any store there that sells this phone. Most will be able to service it for you.
Sep 22, 2007 | Samsung X820 Cellular Phone
Siemens C75 Cell Phone Logo
328 people viewed this question
Top Siemens Cell Phones Experts
Ekse
Trimesh
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
