The fault is with its video output stage circuit. The fault is called "one color predominant' screen. In most cases, this might be to a loose solder terminals at the video output stage circuit board. This board can be located at the neck of the picture tube, will plugged on to it directly. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic /Timeslide, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
SOURCE: 32" Toshiba television Mod. 3357DB
If im not mistaking I remember the toshiba 32" to have an on screen alighnment in the sevice menu.. and I would not recomend that anyone without the proper manual and tools to fool with these adj as I've seen in the past that a set had to be completely redone even the tuner alighnments after someone went in and tryed to adj the set., Now the green tinge you speak of is the CRT getting weak The best way to ajust this would be to see if on the picture tube pc board on the end of the Picture tube if it has any little control on it ? if it does look for the green drive and put on a b&w Picture. slowlty turn down the green drive control untill the pic look almost B&W and you probably wont be able to get perfact grey scale as the crt is weak . If theres no controls on the crt pcb then your gonna need a service alighnment manual and adj the green drive that way. Good Luck
SOURCE: Toshiba 32AF41 Power up Problem and Green Screen
My first inclination would be to check the picture tube, especially if the set is over 7 years old. If it is not that, then anything from bad solder connections to capacitors or a defective IC could be the cause. If it's over 10 years old, replace it. No use flogging a dead horse.
SOURCE: Picture tinted green
green tint & screen dark means that there is a problem in green video circuit. 1 check green video supply . 2 components in green video ckt. 3 adjustment in green video section. 4 check for signal to green video.
SOURCE: Green and purple tv picture.
this is degaussing problem keep tv off for half an hour and if you have changed the direction keep it as it was. if any magnetic thing is there near to tv remove it like speaker or headphone etc. hope this will help.
SOURCE: Red tint while using component cables
Disconnect component cable while observing screen, just to make sure that is your problem. If it is and you already substituted the dvd player and it still happens,, try replacing the cable, it may be defective. If it still happens there may be some kind of a processing defect with the component input of your tv, why not just return to RCA's
