Question about Samsung WE356A5W Washer/Dryer Laundry Pedestal
What does ED mean on a washer machine
My Samsung P801800 washer doesnt start. It just makes a noise and ED shows on the screen.
  • 1 more comment
  • Duster340 Feb 23, 2008
    My P801800 begins it cycle and then stops half way through and gives an E^ code and stops.
  • segduj Jun 25, 2008
    my closed are in the wash started on my washing machine and keeps bleeping and saying ed tried unplugging it nothin works and it leaks water too it should be recalled!!!!!!!
  • Anonymous Jan 16, 2009
    i got a brand new P801 from rich friend (about 2 years old never used) hooked it up...it will SPIN but not wash in any cycle...tried water pressure, cleaned all vents/tubes/traps. Water pressure is fine to the machine.
    It could be what others have suggested - DOOR connector prob, but maybe other electrical? water doesn't even enter machine or start a wash cycle movement
    Trying to fix it before paying for samsung repair tech.
Washing machine samsung SW65ASP showing error code of dE
Posted on Jan 26, 2008
DOOR NOT CLOSED PROPERLY OR POSSIBLY DOOR SWITCH PROBLEM.
Posted on Dec 04, 2007
  • 3 Answers
Had same problem, Best Buy came out (6 wks later). The Drain is not working for whatever reason. Usually though it means a quarter or if you have little kids, a sock or something got in it.
The tech fixed my washer by pulling off the drain tube just above the pump and pulled out a quarter. He said obviously to make sure you dont have loose change in your laundry and to use a mesh laundry bag for small items like little socks. They can work their way outside the drum on front loading machines. The only place for them to go then is in the drain pump.
Posted on Mar 29, 2009
What does flashing nf sign means on the samsung front loader
It means "No Fill". NOt enough water is making it into the washer. Make sure your water connections are good and hoses are not kinked.
Jul 24, 2016 | Samsung Energy Star 3.9 Cu. Ft. Front Load...
Samsung front load washer, jerks and makes noise when it first starts spinningthen it smooths out, and works fine.
on many machines that is normal, the shaking continues until the load is distributed relative evenly around the spinning drum. It is also possible it is the main bearing but I am not sure. The noise I am talking about would have been there since new. These links may help. Washer has noise during spin cycle Whirlpool Maytag Sears GHW9100LW1 Washer is Making Loud Noise
How To Fix Washing Machine Making Noise During The Spin Cycle
http://www.partselect.com/Repair/Washer/Noisy/
May 28, 2016 | Samsung Platinum Front Load Washer -...
Have a samsung washer model WA17XAR showing OE code and makes grinding sound and does not start
Hi this is a link to a short youtube video showing error code 0E, This washing starts and stops as well and the guy fixes it.....CHEERS..
https://www.youtube.com/watch?v=YOvFYcaLp8w
Mar 18, 2016 | Samsung Washing Machines
How do I fix a GE washing machine that doesn't spin or agitate?
aCTUALLY IT MAY BE THE LID SWITCH BUT iM THINKING ITS THE CAM DOGS OR IN G.E MODELS THE AGITATOR COUPLER AT THE BOTTOM IS BAD? ITS ABOUT 7 BUCKS TO REPLACE IT AND EASY
Jun 29, 2015 | GE Profile WPRE6100G Top Load Washer
Code de will not go away
You have not included the Make and model of your washer. Below is a google search for Washing machine error code de
This refers to a Samsung washing machine.
I suggest that you edit your question to include both the Make and model number. This question has been answered before on FIXYA for a samsung washing machine. Link included below. dE
dE1 Ed Door issue ·Check that the door is closed fully.
·Check nothing is trapping in the door.
·Check unit is not overloaded.
· If problem persists please call the customer support team.
Samsung washer machine error code dE
Aug 16, 2014 | Washing Machines
When I turn my Samsung VRT front loader on, the hourglass will not go off and washer start.
I am having the same issue as well i.e i can set the cycle but the washer wont start (the hourglass Icon remains lit). If i press the off button. The display shows off but the display doesnt shut down. Thought this might a control board issue. Bought one off of ebay & replaced it. Did not make any difference (p.s the machine is outside of US so calling service is not an option).
Jun 19, 2012 | Samsung WF330ANW 4.3 Cu. Ft. Front Load...
My neptune washer stop working. has power but doesnt cycle. shows a FL code. cycle i mean as spin to start washing
FL means that the door isn't locked properly. Make sure that its locked tightly and restart the cycle
Feb 16, 2011 | Maytag Neptune MAH5500B Front Load Washer
Samsung P801.washer....Error Message " ED" WHY??
"ED" is a door open error. try Closing the door properly or else there might be jam at the door.
Dec 12, 2008 | Samsung WF337AA Front Load Washer
Samsung VRT washing machine
nF means that washer tried to fill but was unsuccessful. Water supply valves needs to be fully open. Lines may be kinked or screen by the hose hookup at the washer end may be restricting flow. Check to ensure the screens are cleaned by removing hose and pull screens and clean them then try the washer again
Nov 24, 2007 | Samsung WF337AA Front Load Washer
Samsung WE356A5W Washer/Dryer Laundry Pedestal Logo
996 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
