Was cranking but now it ignition clicks but will not turnover.
Dead battry. Charge batt. Try again. OR jump start with cables from 2nd car or tow truck. You may have service with your insurance for jump start at no cost. Once started you need to check the charging system to see if thats why it faild. Either alternator (charger) is faild or battery is failed. Generally its that simple, but somtimes not. Drive it to an auto parts store, they may put a meter on the car to check voltage while running. If voltage is 14 -15 + volts while running, then alternator is likely good and you need a new battery.
Good luck
