Question about Whirlpool LEB6300 Electric Dryer
How old is this dryer?
The dryer looks pretty new, but not sure of it's age. I also got the washer LSB6300. I assume they are both about the same age they were originally bought as a pair.
  • 447 Answers
From like 03-05
Posted on Oct 03, 2007
SOURCE:
Washer making loud noises, but still works... For now. Just completed a normal hot/cold wash and spin/rinse cycle with no problems other than it making a number of cyclic noises throughout, until the
Good morning Mike
The thought that comes to mind is, there are some coins,nails or screws rattling about in the machine. I have not emptied all pockets. It would be wise to take a look at the troubleshooting ages in the manual. Kolbrun
Feb 05, 2015 | Kenmore 700 6972 Dryer
We have an older dryer (ultimate care - super plus capacity) 12+ years old. It no longer "heats". Drum is still turning. I am assuming it is a thermostat - how much do those cost to repair?...
When it doesn't heat it could range from the timer to the heat element to the thermostat or even the motor so it could be as little as $125-350 to repair.
Aug 12, 2011 | Whirlpool Dryers
My Dryer portion of my GE stacked washer/Dryer will turn on and I can hear the motor running but the drum will not turn. I pretty sure is the belt. I haven't been able to locate a schematic anywhere of the...
Not that easy but go to this web site www.applinace pros.com and look at it's diagram and you can see if you want to tackle this issue, if you do and rn into problems you can get help from us here if you need it.
Nov 13, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
Need to know age of stackable
I purchased mine brand new in 1993.
May 27, 2009 | Maytag LSE7806A Top Load Stacked...
Rain on my machine
Id assume it is electronic and yes it can cost anywhere from 25 to 50 on up on the control to correct the problem.
You might try drying the circuit boards out with a hair dryer before proceeding. Sometimes this will correct a short that has water on it. And sometimes it just prolongs the replacement time.
I suggest you contact a competent repair person to get the correct diagnosis and part replaced. Simple as these things are the only way to be sure your getting the correct part is take the old one and model and serl numbers with you to the parts house and match up the new part with the old one.
Unless you are unemployed and or have the time to do it yourself.
FIrst locate your diagram wiring- this should mention the water fill circut. It may be on the main board and this could be a pretty penny.
If this helps you please rate me as high as you can and thank you for using fix ya.
Apr 28, 2009 | GE WBSR3140DW Top Load Washer
My Kenmore Dryer turns on and then goes off on it's own
by the time you purchase a part it would be almost half of what a new one would cost. Check for any clogs that may be in a drain and try playing with the dryer door latch. These things could also cause this problem. But a 12 year old washer could just be a motor wearing out from age.
Feb 11, 2009 | Kenmore 62602 Electric Dryer
Whirlpool LSB6300 died mid-cycle now only clicks
HOPE THIS WORK, DON'T FORGET TO RATE ME
  • Timer is fried.
  • Washer went off-balance and tripped the off-balance switch.
  • Dec 28, 2008 | Whirlpool LSB6300PW Top Load Washer
    TCO & HLtherm on Dryer
    I think you've got your bases pretty well covered. I don't see a reason for you to replace the hi-limit as well. At less than an ohm, I see no reason to bother with it.
    Oct 25, 2008 | Kenmore 63942 Dryer
    Parts for old inglis dryer
    http://www.myapplianceparts.com/index.asp
    These people can find a lot of hard to find parts. I know Inglis is owned by Whirlpool now, but dont know the age of yours, or how long ago this happened. Door switches were pretty much the same, so it shouldnt be to hard to find what you need. Let me know if you need any further help. Jim
    Nov 21, 2007 | Dryers
    Whirlpool LEB6300 Electric Dryer Logo
    Top Whirlpool Dryers Experts
    Marvin
    Marvin
    John Tripp
    John Tripp
    Smitty
    Level 1 Expert
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
