Question about Denon AVR-886 Receiver
Denon avr-886 VERY FRUSTRATED
HELP> When I turn the receiver on it turns on for 2-3 seconds and then shuts off. The power button also blinks red for several seconds. Please help....verrrrry frustrated! Thanks
  • 4 more comments
  • pambyrich Oct 25, 2008
    Here is a Denon AVR-886 7.1 Channels Receiver, there is no remote and there is a problem with this unit. It powers on and scans the channels, after about 3 seconds it shuts off
  • Anonymous Nov 12, 2008
    The same problem happened to me yesterday. the system volume went up the changed setting from tv to receiver, popped now the system only powers up for 4-7 seconds as it scan the channels and goes back off. nothing changed from the night prior, no one touched it and now i have this problem. i have checked all the speaker connections to no avail.
  • Anonymous Nov 21, 2008
    i have the same problem even when nothing is hooked up to it,just pluged in
  • dburas07 Nov 21, 2008
    shuts off even when the only thing hooked up is the plug
  • Anonymous May 06, 2009
    I had the same problem unit turned on then off with in 2 to 3 seconds even if not other item was connected
    took it to a shop in Pickering, Ontario, Canada they fixed it for me
    the place is called
    Vistec Electronic Services Inc. 905-509-7399
  • Anonymous Mar 29, 2014
    This is for an SR5097 Marantz receiver
    The machine auto shuts down after several seconds when turned on and then blinks red on power button.
    Any help is much appreciated in helping me solve this.
    Thx,
    Josh
Remove all speaker wires, than start adding one speaker ata time. after every speaker you attach, turn the reciever on, (meaning you attach first speaker than turn it on, if OK turn it off than attach second speaker than turn on).
One of your speaker is cross-over and when you reach this particular speaker, the reciever will turn off with a loud thump. you have to change the pos and neg wires of that speaker.
Good luck
Posted on Dec 26, 2007
Read the manual. You've either got crossed speaker wires, it's overheating, or it's a more serious problem. The same just started happening to mine, so I'm taking it in.
Posted on Nov 13, 2007
SOURCE:
Red power light blinking on my denon avr 1907, tried reset procedure, no speakers hooked up now and it still goes from green light to blinking red light and shuts off...Any clues?
This is a protection mode. The receiver protection circuit detects an internal problem like missing power supply voltage or blown channel and shuts down the receiver. You need to bring the unit to a repair facility.
Sep 26, 2011 | Denon AVR-1907 Receiver
Power button turns green, flashes and then turns red and flashes.
While working it stops and flashes red approximately 2 seconds interval
Causes
Protection circuit is activated depending on the temperature of the surroundings
Remedy
Switch off the power supply and power on after the temperature have reduced.
While working it stops and flashes red approximately 0.5 seconds interval
Causes
1.Using speakers having less impedance than the specified.
2.If speaker core wire touch each other Protection circuit is activated
Even applying power red flashes 0.5 seconds interval
Cause
Amplifier circuit has failed
Remedy
Switch off the power and contact denon service centre
Thank You
Sep 07, 2010 | Denon AVR-789 Receiver
Whenever I start playing on my xbox or playstation, the receiver will shut off (the red light is blinking around the power button). Once I hit the button, it stops and then I can turn the receiver back...
does it only shut off on high volume or a loud noise?
It's the amp tripping to protect itself.
look out for a shorting speaker wire or faulty speaker etc. disconnect each in turn to find out which
Sep 03, 2010 | Denon AVR-987 Receiver
Denon avr -1709 how do i get it reset to factory specs
SWITCH OFF THE UNIT..PUSH AND HOLD DOWN BOTH SPEAKER A AND SPEAKER B BUTTON WHILE HOLDING DOWN BUTTONS TURN ON MAIN POWER THE DISPLAY WILL FLASH WAIT FOR 3 FLASHES THEN RELEASE. THIS WILL RETURN EVERYTHING BACK TO RFACTORY DEFAULT
Mar 21, 2010 | Denon AVR-1708 Receiver
What is the master reset code for the denon avr 1508?
Turn the unit off by main switch (not a standby button).
Press and hold "Speakers-A" and "Speakers-B" buttons and turn on main switch.
Display blinks.
Release the buttons after 3 seconds.
Receiver is reseted.
Jul 20, 2009 | Denon AVR-1508 Receiver
I got the same problem with my Denon AVR-2105/885
Your receiver is going into protection. The first thing to do is disconnect all speakers at the receiver. Unplug the power cord, then let it set for 30 seconds. Plug it back in and power it on. If it stays on, you have either a wire shorting out at the back of the receiver, something that has pierced the speaker wire en-route to the speaker, a wire touching the other at the speaker or a blown speaker.
Speaker wires should only be trimmed about 1/2" bare at the terminal and make sure you twist the braid so it does not fray. Then connect speakers one at a time, testing the receiver power each time until it either shorts and cuts out, or, you have solved the problem. Hope this helps. If you need more help, post a comment and I can help you some more
Jul 09, 2009 | Denon AVR-1604 Receiver
When I turn on my receiver, it automatically turns off and the power button flashes red. Prior to shut down, the receiver display notes "Tuner Ext. In" What's the problem? It has worked p
Protection circuit turns off the unit because of critical conditions- wrong power supply voltages or one of the power amplifier channels is bad. First, visual inspect the power amp board near the heat sink for burned resistors, test outputs for a short. If there are no problem you may try to turn the unit on and you have several second before it shuts down to check power supply voltages and power amp output voltages and bias, then ... Long story you'd better take it to a repair shop or repair at ebcelectronics.com
May 09, 2009 | Denon AVR 2808Ci Receiver
Denon AVR 886 only shows analog input
Are your speakers able to handle the 886's power. I have the same reciever and changed by speakers as the Denon would turn off instead of frying the speakers.
As for the digital, have you used the option to change your audio feed and video feed. (for example - I'll show photos through the front input but use the CD -digital for music. Maybe the audio feed is locked onto an analog input. Just a suggestion.
Jan 01, 2009 | Denon AVR-886 Receiver
Denon 4308CI power
Tienes un problema con los amplificadores de audio de tu aparato.
Mar 17, 2008 | Denon AVR-4308CI Receiver
Denon AVR-886 Receiver Logo
676 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
