Question about Motorola Mobility RAZR V3
Razr phone charge
My phone wont charge... but it will recognize that the charger is pluged in, and will only charge if i'm holding it at a 45 degree angle... whats up with it?
    Brigadier General:
  • 7,752 Answers
That means your charging port needs to be replaced so take the phone to any mobile service center to have them replaced it there for you.
Posted on Feb 15, 2008
SOURCE:
Motorola razr2 v9m wont charge
My guess is that the charging port in your phone has gone bad. By holding it a certain way, you may be reconnecting it just enough to make the connection. Probably have a loose or broken wire inside your phones port. You may also see this is a problem if you try to hook it up to a pc.
Feb 05, 2010 | Motorola Mobility RAZR2 V9m
My razr will not hold a charge. Changed the battery,helped a little while but now it is doing the same thing.Dies constantly.
The charger is bad, not supplying enough current to bring the battery to full charge.
Or your replacement battery is bad.
There is a small possibility that the charging circuit inside the phone is bad.
So, before you spend money on a charger, see if someone will lend you their charger and let the phone charge over night. If it holds a charge then you know the charger is bad.
Good Luck!
Jan 03, 2010 | Motorola Mobility RAZR V3
Razor cell phone wont charge
steps... 1) check by using another charger...if it gets charged then change ur charger.. 2)if its not getting charge then replace the battery and then try charging...if its again not working then battery problem..change it 3)if the battery s in proper condition then the problem s with the phone charging socket..change it for cost!!!!!!!!
Oct 26, 2009 | Motorola Mobility RAZR V3
Razr v3 drained battery charging
the desk top charger wont be working for your device and I suggest you to replace the battery on to another mobile phone and try charging it
Dec 26, 2008 | Motorola Mobility RAZR V3
Phone wont hold a charg and wont turn on
what you have to do is to clean your phone using isoprophyl alcohol i mean you clean the main mother board then you dry it using hair dryer ,after all that try to replace the battery it has reach it death neal the cells inside they are no longer able to hold the charge.advice by dogy.
Jan 04, 2008 | Motorola Mobility RAZR V3c Cellular Phone
V3 Razr is dead, wont charge
take it to a local cell phone dealer and see what they say. most likley bad charger or bad connections.
Jul 08, 2007 | Motorola Mobility RAZR V3
Razr wont chage
GO TO SETTINGS" .... SCROLL DOWN TO "PHONE STATUS" AND CLICK ON IT. iF IT SHOWS "DEAD" BUT YOUR PHOPMR STILL POWERS UP ... YOU HAVE A FEFECTIVE CHARGER, ALSO ... TRY DRAINING THE BATTERY. THEN SHUT THE PFONE POWER OFF FOR TILL THE CHARGER IS COOL TO YJR TOUCH. LEAVE YOUR PHONE OFF AND PLUG THE CHARGER IN FOR 3-4 HOURS. oNE OF THE TWO SHOULD TELL YOU WHAT IS BAD
Jun 30, 2007 | Motorola Mobility RAZR V3
Razr wont charge
It's really sad that u r on a boat because i suggest u may need to get a desk top charger for your phone. Most times these unable to charge problems comes mostly from water damage or your phone been plugged in to the wrong voltage. Sam !
Charging problems
umm dat mite be a prob becuz the car usually pumps more voltage in the fone...........and if too much is pumped it damage the circuit board and mite even fry the system...... be care ful and keep trying the wall charger..........hope it works
Feb 21, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
104 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
