Question about Motorola Mobility RAZR V3m Cellular Phone
V3M won't load main screen
Today I change a pic from my miscro SD card to the phone's memory the pix was really big in size, but I tried to put it as a Wallpaper the moment a selected Set As Wallpaper the phone frozed, I couldn't turn it off so I took the battery off, when turning it back on, the phone goes thru the Verizon wireless animation then my greeting then shows my phone # and shows Icons like Signal Battery EVDO , everything looks good then the screen blinks and shows no signal no EVDO, battery stay the same; can power it off unless is removing the battery, please help!!! How do I do a resent of the phone without accesing the menu. yesterday for some reason I backed up all my contact numbers, so anything can help me fix the problem wil be really appreciated. Thank you in advance.
    Brigadier General:
  • 7,752 Answers
The phone's firmware needs to be reflash take the phone to a mobile service center and have them reflash the phone there for you, this should correct any issues that you may have at present.
Posted on Feb 09, 2008
SOURCE:
How do i change my internal memory settings for LG optimus e400?
Internal memory is different than SD card memory. You only have 800MB free on your phone's harddrive, you still have 1GB of space unused on your SD card. Today's apps are large, some are even 1GB big! I would go and purchase at least a 16GB card for your phone. They are around 10 bucks now a days. Then on your phone, go to your settings and select the big apps, there should be an option to move them over to the SD card.
Oct 18, 2012 | LG Optimus E400 Black 3g
How do you bring up pics from a memory card from an old phone to a new phone without erasing them (new phone is Motorola razr v3m)
There are two ways to do this, you either transfer the picture from you old phone to your new phone through bluetooth, or just take out the memory card from you old phone and insert it in the new phone.
In some cases, the picture might be to large to display in your motorola, so i will advice you send the picture to you computer and compress it to a reasonable size (maximum 500kb) and put it back in the memory card and it will definitely show.
Jan 15, 2010 | Motorola Mobility RAZR V3m Cellular Phone
Doesn't read my SanDisk memory card
Here's what you do;
go back to the store, smack the clerk upside the head for giving you bad advice, and trade the 4gb for a 2gb.. (or the razr for another phone). The V3m doesn't support SDHC cards; only SD ones. SD are 2gb and below, while the HC (high capacity) are 4gb and up.
Sucks, doesn't it..
Mar 06, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Nikon coolpix L18. Can't put pix on comp. format card
I suggest you to remove the card from the camera and use a memory card reader to transfer the pictures to the computer. Note that the memory card should be formatted in the camera. Once the pictures are transferred you can reinsert the memory card to the camera and then format it in the camera.
Jan 15, 2009 | Nikon COOLPIX L18 Digital Camera
Pny micro sd memory card
Most PCs are like that. I don't know what it is but the computer won't do it for mine neither. To put music and such on you sd card for your phone you must format the card while it's in your phone. Goto setting, Memory, Card memory, then click on opions. From there it will say "Format Card". Do it and the lock code is the last four digits or your phone number. After that's done to load music and such you put the sd chip onto you computer and transfer music to the folder on the sd card called "My_music", pix to "My_pix", and so on....
Oct 08, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Trans flash card
The razor only supports upto a 2 gig sd card.
Aug 29, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Playing music on RAZR V3m
i have put music on the sd card but wen i go to sounds and push the select button it wont work. please help
Apr 20, 2008 | Motorola Mobility RAZR V3m Cellular Phone
How to download my pictures off my motorola V3 phone to my Vista Computer
If all you did was have your provider activate a new phone then the pictures on your old phone should still be there. If, on the other hand, you had the provider activate the old phone to a different number they may be gone.
I'm a bit confused from your post. Are you saying your old phone was a Razr and the new phone is a Razr too?
Does the old phone allow you to use a memory card? The easiest thing to do, assuming you cannot locate the software, would be to buy an inexpensive memory card that fits into your old phone then transfer the images to the memory card. There are adapters you can purchase for a few $$ that will allow you to plug this little memory card into a USB port on your PC.
Let me know if you need more help.
Dec 19, 2007 | Motorola Mobility RAZR V3m Cellular Phone
LG Prada Cant get music on to the phone
If you have a memory card in the phone, you need to move all files to that... then you will be able to download things through bluetooth and move them also to the memory card.
Oct 13, 2007 | LG Prada KE850 Cellular Phone
Micro SD Not Reading
I have same problem with A1200 not recognize micro sd card.
some one help ,Please.
Thank - you.
Oct 07, 2007 | Motorola Mobility A1200
Motorola Mobility RAZR V3m Cellular Phone Logo
82 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
