Question about Panasonic CY-VHD9500U Car DVD Player
No sound went to turn on the dvd player and there is no sound through radio or head phones...any suggestions?
Surf the FM radio setting by the decimal. sooner or later one will display the audio. mine is 98.1 or something.
Posted on Jul 16, 2008
I purchased a 2003 Yukon w/ this identical problem, I found one of the wire harnesses on the back of the main radio head to be loose (back right as you pull the radio unit out. I made sure it was plugged in tight and everything worked.
Posted on Feb 24, 2008
SOURCE:
Dvd not playing over the radio
If you have a DVD player AND an FM Modulator then this is not a OEM part, meaning it's not in your service manual. An Original Equipment Manufacturer part wouldn't require an FM modulator. This is an aftermarket part, hardwired into your vehicle and the fuse should be located under your dash near the main power harness coming from the ignition.
Feb 09, 2013 | Car Audio & Video
Radio sound goes on and off--the closest radio stations won't even pick-up. If you bump the side of the unit it will play GREAT for a short, very short time just fine then back to on and off soun
sounds like you have a loose wire, what wires are you moving under the hood... do you mean behind the head unit? i'd trace each wire individually until you find one that has a poor connection, if they have wire crimps on them so you can't tell, cut them off one at a time and re-crimp them/twist them together.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Feb 09, 2012 | XO Vision XOD1742BT Car DVD Player
I have tried everthing i can to get the dvd player to be heard over the car speakers but can only get the sound on the head phones. Are these Rosen A7 dvd players designed to play over the radio or not?...
Put a cd in the dvd player then tune to the channel and it should work, then try a dvd.
When dvd player does not boot up and display the Kia logo, try moving the door as the hinge turns on the screen and sometimes the connection in the hinge can play up a bit.
Apr 13, 2011 | Rosen A7 Car DVD Player
Vcr gets sound but no video. dvd works fine
it sounds like the video head is dirty and needs cleaning, buy a vcr cleaning tape and follow directions on how to clean the heads... Radio Shack should have the cleaning tape....hope this helps.
Dec 29, 2009 | Philips Magnavox DVD/VCR Dual Player
I would like to try to clean the lens as suggested
go to any radio shack or even a walmart electronics department and purchase a DVD head cleaning disk.
Jun 11, 2009 | Samsung DVD-F1080 DVD Player
AVIC-N2 AM fm radio XM radio Backup camera
Check the connections at your brain, you probably pull it loose when you removed the N1. Goodluck.
Mar 24, 2008 | Pioneer AVIC-N2 Car DVD Player
Mintek portable DVD Player
Defective audio preamp IC. To a shop it must go, unless you fancy yourself a "techie"...accordianman
Nov 07, 2007 | Mintek MDP-1815 Portable DVD Player
Panasonic CY-VHD9500U Car DVD Player Logo
381 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
