Question about Brother SE-270D Computerized Sewing Machine
BROTHER CS 8150 Shuttle Problem
I can't reinstall the shuttle correctly. When I start up the machine it yanks on the fabric as it's feeding through. Is there a special way to reinstall the shuttle? I can't figure it out from the manual.
SOURCE:
  • 399 Answers
SOURCE: I have a Brother SE-270D
its the problem of the timing belt in your machine its extra loosen or extra tightned or is slightly came out of its position or finally broken.
as the machine is proper just missing the proper speed as it should be .
it is running continuosly as you stated.
check the timing belt and make it proper if its worn out and needs replacement this is how its done
There is an adjusting screw on the right side of the machine head. Follow the motor bracket to the machine head and loosen that big old screw or bolt which will raise or lower the motor giving you slack to remove or replace the belt.
feel free for further queries
thanks
Posted on Sep 19, 2008
SOURCE: How do I disassemble my
If you or someone you know is mechanically inclined, you will need to take five screws out of the back including a hard to find one under the foot raising lever (lower the foot), then one form the front that is under the thread cartridge, and you will have to remove the bobbin winding plate cover which is held by one small screw, and then remove a small screw from the support bar.
Posted on Nov 10, 2008
bibleman01
  • 334 Answers
SOURCE: Brother CS-8150 Won't Work in Reverse
Look at the feed dogs under the foot see if they are raised high enough to pull the material through.
Posted on Dec 05, 2008
jrrysthl
  • 9 Answers
SOURCE: My bobbin shuttle broke and I can't find anyplace on line to orde
Do a search for "sewing machine parts" and look at the web sites to find what you need, or email them for your part.
Posted on Dec 13, 2008
SOURCE: Brother PC-420 -bobbin became tangled: removed
Replaced needle.
Posted on Mar 22, 2009
How can I set shuttle timing?
go google and type in ---singer sewing machine needle and hook timing procedure
yes it is a singer but the principle is the same for all makes of machines and the detail is good
If you like change the search from singer to brother and include the model number
Jan 23, 2016 | Brother CS-8060 Computerized Sewing...
My needle thread wrap around shuttle hook how do I repair this? on my Brothers CS 8060
Barbara,
Upper thread looping around the shuttle is typically caused by improper threading through the upper tension disks and takeup lever. Check the instruction manual, carefully rethread the top of your machine and make sure the presser foot is in the down position. If the problem continues it may indicate an issue with tension disks. Remove the upper thread, fold a clean piece of fabric and with the presser foot raised to open the tension disks, place the fabric it in the thread path, through the upper tension disks. Lower the presser foot and draw the fabric back and forth to clean any build up of grime and wax from the disks. Lift the presser foot, remove the fabric, rethread and try again.
If the problem persists, you should not need any tools to remove the shuttle to inspect it - sometimes it is necessary to remove the needle plate to lift it out. Check the edges and underside of the plastic shuttle for marks caused by needle strikes - these can catch the thread causing the issue you describe. If there are marks, you may be able to polish them out with fine (600 grit or higher) wet and dry paper. I generally replace them. Also check the tip of the hook for marks - you can often feel these with your fingernail. If they are present, you may need to get a mechanic to polish them out.
May 31, 2015 | Brother CS-8060 Computerized Sewing...
Bobbin shuttle doesn't move
Look in your book.
- There is a bobbin (clear plastic) it rotates.
- The bobbin fits into the bobbin case (black), it does not rotate.
- The bobbin case is nested into the shuttle which does rotate.
There is no bobbin shuttle.
Aug 19, 2014 | Brother CS-8060 Computerized Sewing...
Brother embroidery machine broken
make sure the bobbin thread is wound and installed correctly
remove tangled thread and clean lint out from under feed plate
clean and remove shuttle to clean out area with lint brush
inspect bobbin for burs and scratches...make sure when reinstalling shuttle and bobbin that it rotates freely
hope this helps
Feb 04, 2010 | Brother SE-270D Computerized Sewing...
I need to know how to change the bulb on a brother ps 33 sewing machine!
Hi, thank you for using FixYa! I don't see a model PS-33, however; you posted in the CS-8150 machine section, the link to the manual for a CS-8150 machine is attached. It has a section for winding and installing the bobbin and another section for upper threading. If your machine is not the CS-8150, please comment with the correct model number (PS machines start at number 1450 and increment upwards). If this is the correct manual, would you please take minute to rate this solution? Thank you! Gregg
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_8150_EN_183.PDF
Mar 29, 2009 | Brother CS-8150 Computerized Sewing...
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
Nov 13, 2008 | Brother CS-8150 Computerized Sewing...
Lower thread tangles and machine then locks up
I have the same problem. When I take it to my shop, they keep telling me there is a special order for reinstalling the shuttle case and plates on top but I get home and can't duplicate what they've told me. If you figure this one out, please let me know. [email protected]
Feb 16, 2007 | Brother CS-8150 Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
74 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
