Question about HP vs15 15"LCD Flat Panel Monitor
Pavilion f1503 Hello i have a hp pavilion f1503 when i turn the monitor off the video goes off but the back light stays on.
I have a problem with this monitor too. i have been plugging it in and turning it on and i see that the display is working fine but the black light only stays on for a split second. i did take it apart and checked the lights and found that the top black light is not turning on while the bottom one stays on for a split second. i believe there is a problem in the circuitry and if i do need a new piece how much would this cost?
Posted on Mar 25, 2008
    Problem Solver:
  • 13 Answers
Sounds like you have a problem in the inverter board. When you shut off the monitor the powers is being shunted from the input but the inverter is still energized and thus florescent is still lit. Please keep in mind that the voltage at the inverter can be lethal, so if you plan to open it, please keep this in mind. You can try to open the case and look for a rectangular board with two set of connectors that contain two cables. This is the inverter board and there will be a warning attached. check to see if you have a solder bridge, if not on the inverter, check the power converter or interface. If this does not work, check ebay for the same monitor that is broken: I.E. damaged screen. you can swap the parts until the problem goes away. Good Luck, and do be careful!!!!
Posted on Oct 03, 2007
What could be wrong with HP Pavilion f1503 screen?
This is usually faulty capacitors. They are in charge of regulating the power of your monitor, with time, they will go bad. The replacements of this capacitors is usually under $10 or $15 usd.
You will need to open the screen, identify, unsolder and buy the new ones to later on solder back and BOILA!
Aug 19, 2014 | HP Pavilion F1503 15" LCD Flat Panel...
How do i replace the back lightin an hp pavilion f1503?
Spare fl-tube is expansive. Not worth the trouble. Just buy a new monitor with LED backlight.
Nov 18, 2013 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1503 only displays a split second?
well, its a 2003 LDC 13 years old ,
its bad
the monitor itself of the power pack to it is bad.
you can test it on any PC< or laptop made
if its dead on all , then its dead.
what more needs saying,
older LCD monitors had old CCFL, lamps. that love to fail
newer are LED back lights that last for ever. it seems
so up grade?
seems your back light is dead
ever do the flash light trick
shine it at the dead screen see good data
yes, then the CCFL is DEAD< (or its power supply ,deep inside)
fixed may but would never do a 2003, not now.
lots of used good LED for sale,
Mar 09, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
Moniter will not turn on
Check the AC adapter to make sure you do have 12vdc coming out, just need to narrow down the problem before taking the monitor apart.
Apr 05, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
My HP Pavillion F1503 15 inch flat screen monitor has all different color lines on it when I plug it in and it wont turn on??
Have you tried the monitor on another computer? If it works on another computer but just not this one, the first thing I would check would be the video card drivers. If those are fine, you could have a bad video card.
Jun 08, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
My hppavilion f1503 flat panel lcd monitor screen stay blank
The monitor should be plug and play, and you've already figured out that it's not your computer by plugging into a working monitor.
This is most likely the power inverter board in the monitor - this is common in many monitors. If the power light is blinking on-and-off, or just staying on with no image, that's the problem. There is a slight chance that it could be the light itself, but inverters fail more commonly.
If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old it is, you may find it better to just replace it with a gently used one from ebay.
Jun 04, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Find out the power cable
here goes a link to the power cord
Feb 11, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Hp pavilion f1503 momitor
Hold the MENU button for 10 seconds to lock or unlock the OSD
Aug 05, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Hp pavilion f1503 wont stay on
is your computer still running after the screen goes blankl
Jun 09, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1503 1503 15in Flat. screen blanks out constantly
THis is a problem of the invertor board.If you are technically able you need to disasseble the monitor and resolder components around the red or yellow inverter transformers.
Mar 04, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP vs15 15"LCD Flat Panel Monitor Logo
167 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
