Question about Texas Instruments TI-81 Calculator
Black screen my screen is either black or it shows nothing at all..at first i thought that maybe it was the color setting..so i did the 2nd down to lighten the screen but it doesn't work..i replaced the triple A batteries and even replaced the cr1616 battery as well..but its not doing anything..there is no display of numbers or anything..all there is, is a black screen or clear screen...please help!
  • whateva4life Dec 02, 2007
    I have a TI-84 calculator and my sister stepped on the screen so now it is cracked. The calculator still works is just that i can't see all the numbers because of the cracked screen. Does any body know were i can get a replacement screen and about how much it would cost?
  • Mojon Sep 30, 2008
    Yeah, I broke my screen too. It was in my book bag and I ran backwards into a car...embarrassing. Now the screen is broken and it appears black on some parts, even when off. Any idea where I can replace the screen?
Don't rape calculators
Posted on Oct 24, 2008
It´s normaly SW, if it supports flash apllications, intall newest SW. worked for me in 2 i had. i have one ti-83 with the same problem, but once it doesn't suport flash i used it's lcd to instal on another that had a broken one. the lcd its usualy good. unless its broken. hope it helps
Posted on Dec 08, 2007
Maybe it's the brightness setting. I just had that problem and i solved it by first pressing the 2nd button and then holding down the 'down' button for a while.
Posted on Nov 11, 2007
Http://www.xnumber.com/arch3/arch3/000006ef.htm
Posted on Oct 09, 2007
SOURCE:
My hp pavilion elite m9152p shows a black screen. If i leave the computer for a few hours and come back the computer is still on, but the screen is black. monitor says no signal... I always have to hold...
Does the power button flash when there is a black screen? Could be that the laptop is in hibernation mode. Go to the tray icons next to the clock, click the battery symbol, more power options, and change the settings of "turn off display" and "put the computer to sleep" to "never". Usually to get the computer out of sleep mode, you just click the power button to turn it on again.
Hope this helps.
Aug 13, 2013 | Computers & Internet
I have an Acer laptop approx. 2 years old. I am trying to show a folder from My Pictures on a InFocus in 20 series. Projector is up and on computer source. When I start up the computer, the projector...
You need to enable the 2nd video output in the video card settings!
right click on desktop select properties and select the settings tab
Select the monitor 2, click on extend my desktop to this monitor.
Then you can drag windows either out from your main monitor, to up, down, or the sides debends on where you set the 2nd display, you can also change the position of the 2nd screen by draging it around in the middle.
Aug 11, 2008 | InFocus Computers & Internet
It doesn't show colors. It's all black and white. I thought maybe I messed up setting it up, but I didn't. What do I do?
Think about how you have the TV video connected. Maybe tell US what that is. If it's Component Video (3-wire), hmm, maybe one is bad, huh?
Jul 15, 2011 | Samsung HT-DS610 System
How to change the power on default copy mode form color to black & white.
Hello Gary
On the main copy display your device is probably set to the factory defaults which means that when you press reset the device is in "AUTO COLOR". Touch the "AUTO COLOR" tab on the screen and a drop down menu will show. Select "BLACK AND WHITE". Now press the "ADDITIONAL FUNCTIONS"key. Select COPY SETTINGS located at the top right. Scroll down till you see STANDARD SETTINGS and select it. Press STORE. You are fixed!!! Please let FIXYA know I helped. :-) SPINAL
Jun 17, 2011 | Canon imageRUNNER C3380i Color Copier
Hello i have ti-82 and screen is black now i change the batary but still when i open its give same screen. what can i do to fixs this problem. thank you
It sounds like the contrast is set wrong for the calculator. Try pressing 2nd down multiple times until you get the color you want.
May 12, 2011 | Texas Instruments TI-82 Calculator
Poor print quality and I don't think it's the ink cartridge
TRY TO ADJUST THE MANAGE COLOR LOCATING ON YOUR COMPUTER FIND IT AND ADJUST THE DARK COLOR
Dec 02, 2009 | HP PSC 1410 All-In-One InkJet Printer
TI-83 screen is black
The "color" on your screen reset to dark. You can adjust it by pressing "2nd" and the "up" arrow (or "2nd" and "down" arrow) repeatedly.
Aug 29, 2009 | Texas Instruments TI-83 Plus Calculator
Ti 83 plus small black screen?
try pressing 2nd then hold in down arrow to change the contrast
Feb 14, 2009 | Texas Instruments TI-83 Plus Calculator
My VS-50609 Big Screen tv is showing only black and white
Maybe your colour setting is wrong or worse your color tube is no good. You will have to change the screen settings (color). If it wont work probably color tube is gone.
Good Luck
Dec 12, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Texas Instruments TI-81 Calculator Logo
876 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Steve Allison
Steve Allison
Ekse
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
