Question about Janome 1600P-DB Mechanical Sewing Machine
Quilting I have my Janome 1600P-DB set up on a frame, but I don't know how to start. Do I quilt without a foot--only the needle in position--like the professional machines? Do all threads have to be pulled to the top before I begin a line of quilting? I need general info on quilting with a frame.
  • Anonymous May 14, 2008
    skips stitches and breaks thread.I have changed the needle and rethreaded the machine several times. will sew fine for a short distance and then start to skip stitches. Please help. Is almost new machine on Grace frame.
    Thanks, Florence McKeell
Janome now has a darning foot ie it looks like an embroidery foot with a spring designed for the 1600 models. It is metal with a ring where the needle goes down through it. I removed the plastic lens inside the ring and this seems to have resolved the problem.
I usually pull my threads to the top so I can see where they are and not getting tangled underneath.
There are several good groups on Yahoo groups which offer support for starting out on quilting
Posted on Jun 05, 2009
  • 51 Answers
No, you should have gotten some kind of 'hopping foot" or use a darning foot, that appears to move up and down as you sew.
Yes, all threads start and end coming up. If you don't cut a thread, will you are sewing you could run into the threads and stop the machine or tear the fabric. Like a rope across the road, your sewing path needs to be clean, because you can see the bottom of the quilt.
You need to be reading some kind of longarm machine quilting books. Or go to: LongarmChat.com or Sharon Schambers Network
Posted on May 10, 2009
  • Anonymous May 10, 2009
    Skipped stitches are a sign the fabric is rolled too thight or the bottom tension is too loose. Breaking threads can be from the upper tension, or a 'bur" on some threading guide. Run a piece of pantyhose into all the quides and see if it get hung up some where. File down the bur with a nail file. Another trick is to turn the needel a tiny bit to the left. Do some online machine quilting research.
SOURCE:
I have a Janome 1600P DBX. The needle is installed correctly but the thread on top keeps breaking or skipping stitchings while free motion quilting? the quilt shop says it is not out of time. I have...
Is it a new needle? a dull needle or one with a burr on it can cause those problems that you mention.The kind of needle you use is also very important. I like to use a 70/10 or 80/12 jeans needle depending on how thick the thread is.
Apr 20, 2011 | Janome 1600P-DB Mechanical Sewing Machine
What needle do I use with the Janome 1600P which I am using with the Super Quilter frame? I've had three different suggestions from 3 different quilting shops. Please help me. Leslie
The needle HLX5 is proper for the 1600P, if it is a 1600 PDB the the DB x K5Q1is the correct needle. Normally a size 14 or 16 is good for quilting.
Doug
Jul 22, 2010 | Janome 1600P-DB Mechanical Sewing Machine
Top thread keeps breaking on my Janome 1600P.
I had a similar problem and then realized that the thread on the top had a **** on the spool it was catching on.
Sep 23, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Skipping stithes
Try practicing on a test piece before moving on to the quilt. Batik fabric is beautiful! I would check the thread size and needle. I tried quilting with invisible thread and had the same problem. The minute I changed to 50 wt.thread and a new needle the problem disappeared. I've found that 40 or 50 wt. thread works best on my Janome.
Oct 19, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Machine vibration
check to see if the machine is setting securely on the quilt frame .also check to see if the frame is setting level on the floor
May 01, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Frame quilting with janome 1600 db
am I right that the feed dogs do not drop on this machine?
Yes, this is correct....but you have to change the needle plate to a thicker one, so the feed dogs will be below the needle plate.
Feb 13, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Janome 1600P-DB Mechanical Sewing Machine Logo
561 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
