Question about RCA 32V524T TV
RCA 32V524T my tv shut off in the middle of a dvd. i tried to reboot the thing and when i did the tv seems to be making a sound normal when turning on the set. the next sound i heard was a very short beep. i then looked at the power button and it flashes instead of just going solid. any help would be greatly appretiated. thanks, brick
    Genius:
  • 1,694 Answers
Probable EEPROM issue--What is the service #? (Has three additional characters after model #. EXPERIMENT==1)remove EEPROM-be careful not to damage it. 2)Install 8 pin plug-in socket--observe pin 1 indicator. 3)Plug back in original IC==may work ok,if not replace w/pre-programmed IC from HB Electronics.
Posted on Oct 03, 2007
SOURCE:
No sound on my 32 inch Olevia flat screen
Check to ensure there any peripherals on mute. (cble re,ote,Tv remote etc. Shut down all the components ,Let Tv sit off for 30 or si seconds, then turn on the TV,set volumne sround 1/4 then turn on the tv. If you have cable make sure the se on TV for input.. It should set to correct channel.The same thing occurred on my TV. 14" flat. The above was my procedure. Sound came on on reboot or it was coincudental to the cable carrier correcting something on their end.
Won't hurt to try. Or you can do what they always tell you when you call it in. Turn off the cable box, Unplug the power cord, wait 30 seconds and turn the box back on. Then give it time to reboot. Good Luck, Problems like this is the reason for slogans like "it's the small things that count" Probably something minor hopefully.
Aug 03, 2014 | Televison & Video
TV shuts off after watching netflix or it starts to reboot
I have a similar problem with HULUplus - I think I'll return the TV to WalMart and try another brand. It's the second VIZIO I bought in the last 5 mos. that has had issues. The first TV had popping (sounded electrical) sounds, also cut out sometimes. Would U-Verse have something to do with it? That may be a dumb question, but who knows?
Jan 22, 2013 | Vizio VW42LF 42 in. LCD HDTV
REPLACED POWER BOARD TV TURNS ON DISPLAYS PHILIPS AND SHUTS OFF ,BUT LIGHT BLUE INDICATOR LIGHT STAYS ON
If no signal (whatever the reason) most sets with a solid blue screen will shortly shut off.
A few things to try first:
Unplug set, a box if used, a receiver if you have it in line---wait a while and plug each back and wait to see if they reboot and restore signal.
Also look to see if you can get the set to a video input before it shuts off---A DVD etc should be connected and on when you try that.
May 26, 2012 | Philips 40PFL3705D 40 in LCD TV
Tv
check the simple things first:
Speakers in the set are not switched OFF.
If using a box for signal sound is not turned down there--also unplug such a box and or the TV and plug back--will allow the unit to try to reboot.
Look to see if have sound when a DVD etc is connected to rear inputs on the set.
Let me know what you find or if have questions.
May 24, 2012 | LG 32LG30 32 in. LCD HDTV
The sound has gone on my tv
Sound is not muted or turned low on set or a box if used.
Speakers in the set menu are not switched OFF.
DVD etc works and has sound--not the set in this case and if above not the issue--reboot the box if used and if using HDMI try another means of connection.
Apr 27, 2012 | Televison & Video
Turns on, no picture or sound, light blinks 5X, reboots itself
First thing is to check the lamp. you can easily change this yourself.
May 26, 2009 | Samsung HCM4216W 42" Rear Projection...
Disney pixar cars tv/dvd combo turn on but shuts off in minutes
Ours did the exact same thing.. I Decided the remote thing was worth a try. I turned the TV to DVD (without a DVD in the player) pressed the set up button (on remote) and Restored the Default option. (Highlighted Default; highlighted Restore then pressed OK) Then exited the set up. I did this twice just to make sure, LoL well.. it's been on over 4hrs now with no problem.. seems like this fixed it.. hope it helps!!
Mar 10, 2009 | Disney Electronics Single Disc Boombox,...
Problem setting up DVD home theatet sound system sc-pt460 with my vierra panasonic TV. The two appropriately connected with HDMI plus Optical cables. Mainly wish to use it improve TV sound. Have got it...
to see the dvd sound menu option you must be on the correct input selection for your tv. ie. if its Scart, then AV1, or if HD then HDMI 1 etc. then you see the options. as for sound being variable, you can adjust the sound for each speaker in this mode. Main thing for having surround sound with normal TV is to turn on the sound enhancement mode. also, on your viera link on the tv remote, make sure sound its selected as home cinema. word of warning, leave dvd on D-In option, and when turning the TV off, use standby mode, which turns both systems off, ensuring the link does not break.
Aug 18, 2008 | Panasonic Televison & Video
Split screen picture
Your DVD player is set to the 480p (progressive) scan mode. Place it back to the 480i (interlaced) mode and it should work normal.
May 14, 2008 | Disney D7500PDD Portable DVD Player
Lg lcd 37 inch tv loosing sound
i have the same problem and find that if i freeze then unfreeze the screen it works
Jan 31, 2008 | LG 42LC2D 42 in. LCD HDTV
RCA 32V524T TV Logo
99 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
