Question about Mitsubishi WS-55807 TV
Toshiba TZ50V51 DOG STEPPED ON REMOTE AND TURNED IT OFF(SMALL DOG) THE INDICATOR LIGHT STARTED FLASHING AND NOW THE TV WON'T TURN ON AND THE LIGHT WON'T STOP FLASHING. HAVE INSTALLED NEW BATTERIES, RESET THE REMOTE, UNPLUGGED THE TV FOR A HALF HOUR, BUT WHEN I PLUGGED IT IN THE INDICATOR LIGHT WAS STILL FLASHING AND THE TV STILL WON'T COME ON. ANY SUGGESTIONS APPRECIATED.
    Genius:
  • 1,694 Answers
Small dog or large==coincidental/unrelated to problem!General service includes some very precise soldering==requires chassis pull. One or more micro-fuses will be bad and STK IC's should be replaced.Alignment in servicer menu may be needed after repair completed.
Posted on Oct 03, 2007
TV Won't turn on, Has flashing red light.
Flashes of standby light is fault indication. Count it and confirm the number of flashes occurs at one time switch ON. If you wish to get more details about these blinking codes to Toshiba sets, check this link. Pull up older posts there.
Mar 02, 2013 | Toshiba TP50F60/61 TV
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
I need a code for RCA remote RCR311STR for a Durabrand television model BH2004D.
In order for the 4 component universal remote to control your TV, you must program it with the TV code that matches your TV. These instructions explain the preferred method of programming the remote-the Direct Entry method.
  1. Manually turn on the TV.
  2. Locate the enclosed TV Code List. Find your brand of TV.
  3. Press and hold the CODE SEARCH key until the indicator light illuminates. Then release the CODE SEARCH key.
  4. Press and release the TV key. The indicator light blinks and then remains lit.
  5. Use the number keys to enter the first code listed for your brand. After you enter a valid three-digit code, the indicator light turns off. Note: If you enter an invalid code, the LED flashes rapidly for two seconds. Start over at step 3.
  6. Aim the remote at your TV and press the ON•OFF key. If your TV turns off, you have found the correct code.
  7. Write the code down for future reference.
  8. If your TV doesn't turn off, repeat steps 3-6 above, entering the next code for your brand. If none of the codes work or your brand is not listed, use one of the Code Search methods to program this remote.
Program for VCR: In order for the 4 component universal remote to control your VCR, you must program it with the code that matches your VCR. These instructions explain the preferred method of programming the remote-the Direct Entry method.
  1. Manually turn on the VCR.
  2. Locate the enclosed VCR Code List. Find your brand in the VCR Codes.
  4. Press and release the VCR key. The indicator light blinks and then remains lit.
  5. Use the number keys on the remote to enter the first code listed for your brand. After you enter a valid three-digit code, the indicator light turns off. Note: If you enter an invalid code, the LED flashes rapidly for two seconds. Start over at step 3.
  6. Aim the remote at your VCR. Press the ON•OFF key. If your VCR turns off, you have found the correct code.
  8. If your VCR does not turn off, repeat steps 3-6 above, entering the next code for your brand. If none of the codes work or your brand is not listed, use one of the Code Search methods to program this remote.
May 11, 2011 | RCA RCR311B Remote Control
I have the rca rcu404 remote
Code Search Method
  1. Turn on the device you wish to program.
  2. Press and hold CODE SEARCH until the indicator light lights, then release.
  3. Press and release the device you are programming (tv,vcr, or dbs). The indicator light will blink once then remain lit.
  4. Press and release off-on until your device turns off. You may have to press off-on up to 200 times.
  5. When your device turns off, press the ENTER button and the indicator light will go off.
Code Entry Method
  1. Manually turn on the device you want to program.
  2. Find the code for your device in the code list.
  3. Press and hold the CODE SEARCH button until the indicator light lights, then release.
  4. Press and release the device you want to program, the indicator light will blink then remain lit.
  5. Enter your code using the number buttons.After your code is entered the indicator light will turn off.
  6. Aim the remote at your device and press the off-on button. The device should turn off.
here is the codes for the toshiba tv's : 071, 105, 162, 160, 049, 072, 109, 117, 118, 201, 207, 232
Jan 06, 2009 | RCA RCU404 Remote Control
Toshiba TN 50V71.
the start up or standby power is in need of troubleshooting. I would start by checking the regulator and horizontal output transistors.
Mar 14, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba TZ50V51 - Power light flashes, tv won't turn on
It is hard to say Toshiba is one of the few manufactures that have good step by step procedures for diagnosing ad repairing your television. There is a manual called Toshiba power supply and shutdown circuit troubleshooting. This is a valuable asset to save hundreds of dollars on repair. You can get this manual at the following link it has your model covered in it for 10.99. It is on page 2 of the toshiba section bottom of page. They will even email it to you if you are interested in trying to repair your own set. Hope this helps here's the link.
http://servicemanuals.vstore.ca/
Jan 24, 2008 | Toshiba TZ50V51 50" Rear Projection...
Intermitant failure with blinking light
Is your tv a Toshiba TZ50V51 ? If so, You can get the manual to trouble shoot your toshiba for 10.99 at the following link. It is called power supply and shutdown circuit trouble shooter. It covers your model number. It has step by step instructions to get your set up and running. It is located on the bottom of page 2 in the Toshiba section if your interested.They will also email it too you instantly, If you return to the site and leave your email address. This is a good manual. I have used it myself many times. Here is the link, If you're interested in it.
Oct 20, 2007 | Toshiba TZ50V51 50" Rear Projection...
Toshiba TZ50V51
First step is to use an ohmmeter and check all fuses including
small,soldered in kind called micro-fuses.....F850,F851,F852 etc
.................................T.
Oct 03, 2007 | Toshiba 50HX81 50" Rear Projection...
Mitsubishi WS-55807 TV Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
