Question about Peachtree Software Peachtree Complete Accounting 2004
Opening existing account
I'm not sure what the problem is but every time i go to open my existing account it pops up a error message that says: Error reading General file for Module 4 and that is all it will do it won't let me get in.
SOURCE: Using Peachtree Complete Acctg 2003 w/ Microsoft Vista
may be need to reinstall it again then make update for it
Posted on Aug 11, 2012
0 characters
1 Points
Is it possible to make word repair document?
When you restart a Microsoft Office program after a power failure or similar problem, the program automatically opens any recovered files.
If for some reason the recovery file didn't open, you can open it yourself.
1. On the Standard toolbar, click Open .
2. On the Show pop-up menu, click All Documents.
3. Locate the folder that contains your recovery files.
Each recovery file is named "AutoRecover save of file name."
4. Open the recovery file.
5. Click Save .
6. In the Save As box, enter the name of the existing document.
7. When you see a message asking whether you want to replace the existing document, click Yes.
Any recovery files that haven't been saved are deleted when you quit WorTips
• If you can't open the recovery file, you can try to recover the text from the damaged file.
• To find out or change where your recovery files are stored, click Preferences on the Word menu, and then click File Locations.
Otherwise apply Word Repair Toolbox
Tool has a lot of different tricks, know more at:-
Feb 08, 2015 | Microsoft Office Word 2007 Full Version...
How correct error after save pptx document?
I think you mean you cannot open an existing file. Try via Windows Explorer copying the file, then rename the copy and try opening this one.
Jan 19, 2015 | Microsoft PowerPoint 2007 for PC
.ost and .pst problem - how to migrate from IMAP to POP
Yes you can import old .ost by creating a new user profile with same MAPI details. Once OST file open then export entire data into PST file format through Import Export Wizard.
Get best OST file recovery tool to recover OST file to PST file easily.Download OST to PST Converter Toolbox
program. Without any damages you can remove all bugs from corrupted OST file and save OST file as PST in seconds:
Even if you don't remember previous MAPI setting then Orphaned OST file cannot be open in MS Outlook. In this case convert offline OST file to healthy PST format using a committed OST recovery tool. Because PST file can be easily imported into MS Outlook (POP3 & SMTP) and this is only a safe method to retrieve OST file data.
Get More Details:
Nov 07, 2014 | Microsoft Office Outlook 2007 for PC
Hi. I am do a diploma in accounting and have just completed the myob section. I have had to as my first assignment create a company and do a couple of things. Save file and back it up. I have attempted to...
Its possible that the file you are trying to open is now just a shortcut. If you have made a backup, you maybe trying to open a shortcut to a file now located in another location.
Did you manage to make the backup? Does it work?
If this is not your problem, please write back
Jun 30, 2010 | Myob Accounting Plus (BPJUBC00) for PC,...
We cannot start e- mail, Error message is:
I think your email account is not the problem, but make sure your outlook account setting is correct.. It's a best bet to reinstall the Office.. Good luck...
Apr 29, 2010 | Microsoft Office Professional 2007 Full...
Message: internal error occured pops up.
You will have to uninstall everything that is made by adobe. Adobe flash player, adobe active x. After unstalling that, that should let you put the adobe reader back. Then download the other program I mention earlier.
Nov 09, 2009 | Adobe Acrobat® 8.0 Professional Full...
Problem opening Access Database-upgrade from Access 2003 to 2007
if the form "products" really exists, then your office 2007 security settings are not allowing to load macros. Try the following settings:-
Office 2007 has some security settings disabled by default to prevent any harm to your system.
go to trustcenter settings(click the office button at the top left of the office 2007 screen then click Access options, then select Trustcenter, then click trustcenter settings.)
In trustcenter settings, select message bar then select "Show the message bar in all applications when content is blocked" radio button.
Then from macro settings ,make sure to select "Disable all macros with notification" . Click ok twice to close the settings windows and try opening the file again.
Good Luck
Mar 25, 2009 | Microsoft Access 2003 for PC
Error message
Hi beulah_jane,
What version of Simply Accounting are you using? 2007? 2008? 2009? Using Windows XP or Vista? Are the Simply files stored locally on the C drive or on a network? Can you open a sample company or are you getting the same error?
If you're trying to open the file using a shortcut to the data file itself, try using the Simply Accounting Program shortcut and then opening your file. If you're getting an encountered an error message, try searching through our knowledgebase.
In either case, I or another user can help you in our Simply Accounting Community at
This includes a free Knowledgebase, Discussion Forum and blogs that you'll have access to. You may even find your answer already posted by another user in the forum. We have several knowledgeable users and our business partners going through the forum as well that can help you as well.
I hope this helps.
Andrew C
Simply Accounting by Sage
Online Customer Support Analyst
Mar 19, 2009 | ACCPAC Simply Accounting 2004 PRO...
You need to either use a Domain Account if you are using Windows authentication or you need to use SQL server authentication.
The reason for this is because the user account that you are using only exists on the machine that you are on not on the machine that you will be replicating to.
Sep 24, 2007 | Microsoft SQL Server Standard Edition for...
Peachtree Software Peachtree Complete Accounting 2004 Logo
Top Peachtree Software Business & Productivity Software Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Peachtree Software Business and Productivity Software Expert? Answer questions, earn points and help others
