Question about Sony Handycam CCD-TRV67 Camcorder
Error code E:61:00
When I start to record I have no image either in the view finder or the viewing screen, but then E:61:00 flashes on the upper right of the viewing screen and I can view the image in front of the camera, but only on the screen, not the view finder. Is this something a Sony rep will have to fix?? Thank you
  • Catmando85
    Catmando85 Oct 03, 2007
    Thank you sandrew. Sounds feasable and I will give it a try!!!
    catmando85
  • Catmando85
    Catmando85 Oct 07, 2007
    Sandrew's solution worked! I had to have the camcorder on for it to work, but it worked! THANK YOU SANDREW!!!
    President:
  • 2,961 Answers
Yes it's a sony repair job, but theres a lot of people who have resorted to the following methods before they will part with $200 or so, the camera models are different but the method is the same :- http://www.fixya.com/support/t129748-sony_cybershot_dsc_s50_not_focusing http://www.fewin.com/sony/sony.htm
Posted on Oct 03, 2007
SOURCE:
No picture on screen when switched on
You have not given enough information. Are you trying to see
recorded photos or expecting to see the image from the lens?
You normally have an option to either use the view finder OR the
LCD display. It usually defaults to the view finder and you must activate the LCD with a button.
Nov 02, 2013 | Samsung Cameras
The problem i m having with my camcorder is when i want to record film screen goes blank but i can watch my previous recorded videos
Look in the view finder when recording instead of the screen. if you see the image there then the unit is probably set to look through there. Many of the new units dont' have a full view finder to lens item they actually have a small lcd screen inside the view finder. Check your options for recording.
Also if the view finder is tilted you need to close that before usign the lcd.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
Mar 02, 2011 | JVC GR-DVL820U Mini DV Digital Camcorder
My sony wount record or playback a movie, there is a blinking symbol when i hit record.
I'm Sony tech and can help you to solve problem of CCD-TR818 camcorder.
Tap bottom of camcorder few times with your palm gently, now check playback of tape.
If problem still not solved, let me know what error code flashing on top right of view finder screen.
Thanks.
Dec 04, 2010 | Sony Handycam CCD-TR818 Camcorder
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Nov 18, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Error Code C:31:00 in a Sony CCD-TRV75 Handycam Camcorder
    This error shows that the problem is in mechanical section of the tape loading path. Please contact an expert for mechanical adjustment
 Thanks for using fixya.
May 21, 2009 | Sony Handycam CCD-TRV75 Camcorder
Nothing appears in view finder or on screen when recording
I HAD THIS PROBLEM ERROR CODE C31 : 22 WOULD COME UP AND TRV 118 CAM WOULD NOT WORK. I TRIED EVERYTHING TILL ONE DAY I BANGED IT ON A CARPETED FLOOR ON THE BOTTOM OF THE CAMCORDER 5 TIMES QUITE HARD. THEN THE CAM WORKED JUST FINE! MY CAM HADN'T WORKED FOR OVER 7 MONTHS. NOW I HAVE IT BACK. HOPE THIS HELPS SOMEONE.
Jun 18, 2008 | Video Cameras
Black LCD and view finder
you need to go to the service center for replacing the ccd image sensor...i know it is free for replacing that image sensor cause your camera is one of the recall product due to the production error of the image sensor...log on to the sony site and go the costumer service ...
Nov 13, 2007 | Sony Handycam DCR-HC30 Mini DV Digital...
Camera mode recording/displaying right
what is the model number? if it's 10 years or older you are most likely dealing with bad surface mounted capacitors.
Sep 16, 2007 | Sony Handycam DCR-TRV140E Digital...
Nikon coolpix 5700
at the back of the camera next to the view finder (bottom right hand corner) is a button and icon marked SEL. pressing this button toggles the lens image from the view finder to the lcd screen and back again. IF neither view is available then I suspect your camera needs some TLC at a repair shop. hope this helps.
Jun 26, 2007 | Nikon Coolpix 5700 Digital Camera
ORITE MODEL dV3020 BLANK VIEW FINDER
You have images on the Card- Yes? The flash works -Yes? Now you cannot take pic's is that what you mean. One of many thing- are you getting error messages? Are you sure you are getting images to the card? There may be images on the card but the screen has gone down- If you hold the camera at a slight angle can you see dim images[if yes screen back light down] If No images a connector or CCD problem. Make sure you have fresh batteries Gently squeeze the casing near the bottom of the screen- it may be a loose connector. Depending on how long you have had this -get onto the Seller or Manufacturer's web site tech support- there may be a replacement available. There will almost certainly be no repair option on this type of camera
Jun 23, 2007 | Orite MG370 Digital Camera
Sony Handycam CCD-TRV67 Camcorder Logo
213 people viewed this question
Top Sony Video Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
