Question about Pioneer HTD-510 System
PT FAN ERR
We have a Pioneer XV-HTD510 and when we turn on the power, PT FAN ERR flashes on the display then it shuts off.
  • fox118 Nov 25, 2007
    i have to same problem is there a solution to this problem?
  • rynohof Oct 04, 2008
    We have a Pioneer XV-HTD510 and when we turn on the power, DSK
  • 3 Answers
There is a fan located inside the unit used to cool the output chip. I iwould take a look to see if it is full of dirt, or is not turning.
Posted on Mar 12, 2009
Why xv-htd530 pioneer timer flashes
When the display flashes the time (or --:--) you probably had some kind of power outtage. You should be able to solve this by entering the menu and adjusting the time.
If this doesn't work, report back.
Oct 05, 2016 | Pioneer Audio Players & Recorders
What is the solution to an error code ( OC ERR 1) ON PIONEER XV-DV360
The "OC ERR 1" code is a sign that there is something wrong with the speaker connection(s). Mostly one of the speaker cables is causing a short-circuit, which triggers the safety system. Power off the unit and pull out the plug. Check all the speaker connections (amplifier and speaker side) and make sure that no (parts of the) cable is (are) touching the chassis. Twist the cable ends to a single core if necessary.
Jul 21, 2015 | Pioneer Televison & Video
I have a pioneer dvd/cd receiver player,,, xv-htd540 and the timer light is on,, and the unit wont turn on..
i don't have a solution , sorry . but i am looking for a user manual for the xv-htd540 . do you have one ?? dennis
Jun 01, 2010 | Pioneer XV-HTD520 Multi-disc DVD Player
The dvd player will not play, will not spin -
the internal motor has gome bad change it
Mar 30, 2010 | Audio Players & Recorders
Amp Err
please check all speakers cables for short circuit-disconnect all speaker-put volume low-wait and observe it if no shut down -go to next step-connect your speaker one by one until you find the bad one,start with speaker cable(try another good cable) and then speaker.if shut down happened again while you connect nothing to your system you will have inside problem and ask for service center to fix it.
Jul 07, 2008 | Audio Players & Recorders
Pioneer Component Hi-Fi System XV-EV7.
pioneer xv-ev7 no power timer stand by only...
Jun 16, 2008 | Pioneer Audio Players & Recorders
Timer LED flashing and tv screen not viewing
does the tv have a separate tuner box? if so check the cables i have a pioneer that does that when the connection isnt in sync
Apr 09, 2008 | Televison & Video
Stand by button flashes but receiver wont turn on
I have vsx-d812 that has an AMP ERR in error menu. the troubleshooting was found to be Q696 and Q697 in the DC prot. area on "C" board, up near front toward diplay in center of c board. You can get access to error codes on VSX pioneer unit by pressing "enter" and "adv. surr." simultaneously for 2 sec. The display should show what error code you are experiencing. I believe there are three diff. error codes. 1) AMP ERR 2) OVERLOAD 3) BOAD ERR (not mistyped) I hope this helps pinpoint error code for ya.
Oct 07, 2007 | Pioneer VSX-816-K/S Receiver
5 disc tray opens and then shuts
Your problem could be one of three differnt things. It could be that the open close switch on the front has a bit of resistance to it, sand when you press it the switch starts to conduct and then the machine thinks someone has pressed the open/close switch again, or there are a set of small switches inside the unit that the door makes contact with when it reaches the end of the travel lenth, that is binding or broken, or there is a problem with the switch or microprocessor circuitry that is affecting the open close command. The correct repair procedture would to be to get a service manual and trace out these devices that I have just described.
Oct 07, 2006 | Pioneer HTD-510 System
Pioneer HTD-510 System Logo
393 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
