32 Toshiba TV no picture / bad pciture
One day I turned on the tv but there was no picture. sound is fine. My friend told me to bang on it. (great idea) so I hit the top and I got a picture but it is VERY dark, moved the settings to as light as possible and the picture is like Movie format, where you have the black sections above and below the picture. I know I shouldnt have hit the tv but I had a few beers. Thanks for any help. Suzi
  • Matt526 Feb 16, 2009
    Is it possible to buy a new power supply and if so do you have
    a part number?
    Genius:
  • 1,139 Answers
Hello Suzid, It looks to me like you have a possible power supply issue (poor brightness on screen, shrinking of the picture, and initially no picture) This problem may put you in danger of electrical shock, so I would suggest that you not try to repair this set yourself. I would suggest that you take the television to a television repair shop.The power supply issue could be a low power or a high power supply problem.
Posted on Oct 08, 2007
SOURCE:
Toshiba 32A42/32A42A. Just moved tv to bedroom, worked great for 2 days, now the picture has vertical lines. Turned it off for 15 minutes, picture came on, 10 minutes later lines appear again. Anyway to...
It sounds that there is any loose solder terminals at the main board, especially with the vertical scan output section circuit. It will be best to contact any service technician to get it repaired. Gopakumar Gopalan Google
Mar 09, 2014 | Toshiba 32A42 32" TV
Screen on and off
It is likely to be a problem with ysus board or with power unit
Apr 07, 2008 | Sony WEGA KDE-61XBR950 61 in. Plasma HDTV
My LG 37LC2D picture suddenly goes black and then if I bang on the corner of the set sometimes the picture will return. What is wrong with my TV?
could be the power supply card(s) is unseated..open it up if you dare and re-seat and/or maybe remove and clean the card edge connector contacts with an eraser
May 27, 2012 | LG 37LC2D Television
Toshiba 32a40. The display on the screen shrinks to where it looks like a BLUE FLATLINE. I bang on the sides and the upper back portion of the TV and the image comes back temporarily. But now nothing...
You've got at least one board that's gone bad. Were it mine, I'd donate it to a local charity and get a new one. The charities have volunteers and job trainees that do the repairs, and might be able to make a buck on it, while you get a tax write-off.
Jul 07, 2011 | Toshiba 32A40 32" TV
Toshiba Picture Not On
what you suggesting is that the lcd has a good maintenance needs that have to have cold solder or connectors are sulfated
Aug 22, 2009 | Televison & Video
When turning on the TV, I hear a banging/grinding sound.
If you hear a grinding,whirling,spining or buzzing sound, that sounds to me like the COLOR WHEEL,the reason for that is because your color wheel spins at 5,000 rpms(revolution per minute) and something that modifies the balance of the disc can cause different things,Unfortionatelly the only way to check that the color wheel is working properlyis you need to check it out physically
I did some research and I found the color wheel at DM;http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?CLICK=52978
Please keep us posted.
Jun 14, 2009 | Samsung HL-S5087W DLP TV
TV Picture Pops In and Out Toshiba Color TV CZ27V51
mine was doing the same thing. If i put pressure on the cable input from left or right it would fix this.
May 22, 2009 | Toshiba CZ27V51 27" TV
Every thing works except the sound
press mute on the remote control
Jan 25, 2009 | Toshiba 32A33 32" TV
Televison & Video Logo
891 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
