Back to:
Tags:
NEC 1560V+  15 in. Flat Panel LCD Monitor
Lcd wont stay on
posted by erasmus8 on Oct 03, 2007
the unit will turn on and then it will go blank with the power light turing from green to orange if i turn the unit off and on again it will stay on for about two minutes then off again back to the orange light
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Oct 12, 2007
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I thinkit's avirus?
Rating Locked! (?) erasmus8 has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on lcd wont stay on:
I don't want to Accept this solution
Solution #2
posted on Jan 29, 2008
Helpful (85)
Guest
Rating: 0%, 0 votes
maybe a power supply unit inside the lcd
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Can you Help with these Monitors problems?
Monitors
I got a acer monitor with tic-tac sound when power switch...
Monitors
There appears to be a power problem in that when I switch...
Monitors
When I power up my monitor I don't see an LED comming ON...
Monitors
Screen flickers and flashes. Then settles down for a few...
Monitors
hi dear, my computer works fine but...
Loading problems.
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
