Question about Samsung SmartEther Networking Switch
Samsung SmartEther SS6212
I'M DONT KNOW HOW TO MAKE A CABLE TO ACCESS THE CONSOLE DB9 TO RJ45 PIN SEQUENCE!!
  • 82 Answers
Orange white orange green white blue blue white green brown white brown on the plain side you have to look
Posted on Oct 09, 2007
SOURCE:
I cannot connect using serial console port (no signal / data out of serial console port). I don't have IP address of the DS4100B. I don't have its password... How can I reset it to factory default?
I am assuming you will still need console connection to do a password recovery.. however, here is the link to one password recovery doc that may help.
May 10, 2016 | EMC DS-4100B 32 Port 4Gb SAN Switch
How do you connect to a terminal with avocent dsr8035
You should have a DB9 to RJ45 converter in the box. This converter is used to change from DB9 serial to RJ45, which is the port on the DSR that is used to connect to the serial console.
Should you do not have such connector, call Avocent Tech Support, they will help you to get that converter.
The NullModem Cable might also be requiered
Also remember:
9600
8
none
none
Apr 23, 2014 | Avocent DSR8035 KVM over IP Switch KVM...
Need driver for cisco rj45 to d9
You don´t need a driver. You need a serial port on your PC/laptop and a terminal-software, such as Hyperterminal. Do not forget to set the terminal-speed to 9600 (this is standard on Cisco-routers).
hth, Karl
Feb 14, 2013 | Cisco Compatible DB9 to RJ45 Console...
Im need to cisco cable 72-3383-01 free driver for win 2000
You don't need a driver. It's Hyper Terminal. So use that or Putty.
Jul 10, 2011 | Cisco Compatible DB9 to RJ45 Console...
Not connect from console port
Verify that the correct settings and cable/connectors (rollover cable, correct COM port specified) are being used when establishing the console connection.
From the manual-
3.9.2 Connecting to an IBM or Compatible Device
To connect an IBM PC or compatible device, running the VT terminal emulation, to an
Enterasys Networks module Console port (Figure 3-20), proceed as follows:
1. Connect the RJ45 connector at one end of the cable (not supplied) to the Console port on the
Enterasys Networks module.
Connecting to Console Port for Local Management
Hardware Installation 3-31
2. Plug the RJ45 connector at the other end of the cable into the RJ45-to-DB9 adapter (supplied
with the device).
3. Connect the RJ45-to-DB9 adapter to the communications port on the PC.
4. Turn on the PC and configure your VT emulation package with the following parameters:
Parameter Setting
Mode: 7 Bit Control
Transmit: Transmit=9600
Bits Parity: 8 Bits, No Parity
Stop Bit: 1 Stop Bit
source: Install Guide for Enterasys 1H582-25 / 1H582-51 (http://www.retrevo.com/support/Enterasys-1H582-51-Switches-manual/id/2785dj098/t/2/)
Jun 22, 2011 | Enterasys MATRIX E1 (1h582-51-g)...
Need driver for CISCO DB9 TO RJ45 6FT CABLE 72-3383-0 for my notebook
If I am understanding correctly, you are using a serial to ethernet cable. The serial cable plugs into your laptop and the ethernet end plugs into the CONSOLE port on the Cisco.
From here you use a terminal emulation program like "Hyperterminal" to connect via the serial port. As long as your serial port is installed, no other drivers are necessary.
May 02, 2011 | Cisco Compatible DB9 to RJ45 Console...
I need the pinout for the serial cable? RJ45 to DB9
f211598.png This is for a newbridge or alcatel 3624 mainstreet channelbank - do not use the modem side, only use the terminal side - all is needed is Rx, Tx, and ground - if looking from the "window" side of rj45 connector, or pins-side up on rj45 socket.
Aug 03, 2009 | Alcatel Newbridge MainStreet 3612...
Rj45 male to db9 male cable for ups
If you have a BackUPS CS, you are probably either using it with the USB cable that is supplied or with the 940-0128A supplied by APC, which permits running the UPS in dumb mode. By building your own cable, you can now run the BackUPS CS models (and perhaps also the ES models) using smart signalling and have all the same information that is available as running it in USB mode.
The jack in the UPS may be easily use a 8 pin RJ45 connector. It is easy to construct the cable by cutting off one end of a standard RJ45-8 ethernet cable and wiring the other end (three wires) into a standard DB9F female serial port connector.
PC Signal PC pin UPS Pin UPS signal RxD 2 2 TxD TxD 3 8 RxD GND 5 7 Ground FG Shield 4 Frame Ground Though these UPSes are USB UPSes, APC supplies a serial cable (typically with a green DB9 F connector) that has 940-0128A stamped into one side of the plastic serial port connector.
Here is suggested scheme of original 940-0128A cable
APC Part# - 940-0128A computer --------- Inside the Connector--------- UPS DB9-F | | RJ45 pin - signal | | Pin - Color | | 4 DSR ->|---+ | | | diode resistor | 6 DTR ->|---+---->|----///---o kill power | 8 Orange | | 1 DCD <-|----+ | | | | 2 RxD <-|----+----------------+--o low battery| 3 Brown | | | 7 RTS ->|----------+--///--+ | | | | | +--///--+ | | | | 8 RI <-|----+----------------+--o on battery | 2 Black | | | 9 CTS <-|----+ | | signal | 5 GND --|-----------------------o ground | 7 Red | | 3 TxD | | | chassis | Chassis/GND |-----------------------o ground | 4 Black | | | Not connected | 1, 5, 6, 9, 10 --------------------------------------
Sep 30, 2008 | Digi (76000200)
I cann't connect to my switch
The primary connection method for those switches would be serial connection. In the box there should have been a DB9 serial to RJ45 cable. Hyperterminal default settings would allow you to connect.
Jul 25, 2008 | 3Com 4500 24-Port Ethernet Switch
Open Questions:
See all Samsung SmartEther Networking Switch Questions
Samsung SmartEther Networking Switch Logo
196 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
RONALD CARTER JR
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
