Question about LG DLE0332 Gas Dryer
Clothes dryer not getting hot enough to dry in a good time frame
I just replaced the plug unit for my dryer and everything went well with the replacement. I did a small load of clothes and put them in the dryer for 50mins (usually enough time to dry a much larger load). Clothes were only half dry. There was some heat, but not nearly as much as there was before. What's going on? Does changing the electical reset the themostat?
  • 2 more comments
  • MARISTAR210 May 13, 2008
    I have the same problem. New LG DGL3744D converted to propane with the proper LG propane orifice. The heating is very sporadic. It will only ignite 50% of the time. A typical burner firing will cycle (3) on (1) off (1) on (1 ) off (1) on (3) off. On all the off cycles you can smell propane and the exhaust cools to luke warm. My understanding is that the burner should fire every time the igniter glows. By the way I already had an LG tech to fix the problem. It just happened to work while he was there. I also know more about dryers than he does.
  • Anonymous Jun 16, 2008
    same problern i cleaned the lint from hose to no avail
  • Roadking1450 Feb 11, 2009
    The sears electric dryer takes (2) hours to dry a load. I had the vent cleaned and to no avail it still takes a huge amount of time. The dryer is hot when running.
  • Anonymous Mar 29, 2014
    dryer doesn't seem to get hot enough
I have a hotpiont TDC32 i have changed heating element and thermastacs and it still does not get as hot as it should it takes ages to even half dry has anyone got any ideas please i have cleaned all the filters etc...
Posted on Sep 18, 2008
I have the same issue with my DLG3788W dryer. It seem to have only one setting for heat, rather than multiple heat settings. What can I do or do I have to call someone to repair this.
Posted on Oct 05, 2007
SOURCE:
Dryer control doesn't move on less dry more dry setting and will not shut off when clothes are dry.
If clothes are hot then try dryer on timed dry. If timer does not move then timer is most likely bad . Replace. If timer moves on timed dry it is not getting hot enough to click the cycling thermostat.(If clothes are overly hot above 160 then the cycling therm. is stuck Replace.
Oct 29, 2010 | Dryers
My clothes come out wet after running for a length of time but they are hot
You have an vent issue..If the clothes are hot but not drying your not getting proper air circulation, you need airflow thru the unit to help remove the moisture from the clothing other wise you end up with warm moist clothing... Start unit and go outside to where the dryer vent comes thru the wall and check the airflow with your hand ,you should feel a good flow of warm air. If not some where between the unit and the vent their is a restriction either in the flex duct or the duct work in the wall which will need cleaned out before the clothes will dry in a normal time frame..Plus it cost a lot to run the dryer 2 or 3 cycles to dry clothes Hope this helps Good Luck
Aug 26, 2010 | Maytag Dryers
Whirlpool dryer does not get hot enough to dry clothes.
Clean/repair the dryer vent. If the airflow is restricted the result is the one you just described.
Good luck,
Vlad
First Choice Appliance
Apr 20, 2010 | Roper REX4634KQ Electric Dryer
Slow to dry
Hi!!
Have you cleaned the filter and the exhaust duct??
Lint plugs therm up, the heat sensor shuts off heating element thinking it is hot enough. Result: Clothes not getting dry.
Unplug duct and clean it, also clean the exahust passage of dryer. (where duct hooks to dryer)
Click below if this was helpful, Good luck.
Mar 28, 2010 | Dryers
My dryer does not get hot enough to dry the clothes.It takes about 80 minutes to dry on high heat.
If this is an electric dryer, it would appear that you have a broken dryer element, which would account for the extended drying time.
You can access the elements from the back of the dryer by removing the rear panel. Be sure to unplug the dryer first, to avoid getting an electric shock. You will need a multi-meter to check the continuity of the two (2) dryer elements. Just put the meter into the Ohms setting and check across the two element contact points to see if you have continuity. If you find that one of them isn't giving you a zero "0" reading, that is the bad one.
Go to searsdirectparts.com to enter in your full model number and you can see the exploded line drawing for your dryer and the parts list and prices for the replacement part.
The reason the dryer is taking longer to dry, is because without both elements, the dryer cannot get hot enough to dry the clothes within the normal time, as only one element is having to provide all the heat in an attempt to dry the clothes.
You should replace the element as soon as possible, as having only one heating element working will cause that remaining element to fail sooner as well, since it will be staying one for a much longer time than normal.
Hope you find this Very Helpful and best regards!
Aug 26, 2009 | Dryers
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Dryer gets hot when not running
Getting hot when not started is a great concern.
I have a few ideas why, but this is a fire hazard and I would suggest unplugging and either getting help or replacing.
That said, there here are a few suggestions.
1) if the element is shorted to ground, it will get power to one side of the element and heat though ground. This, again, is serious.
2) if it heats forever and doesn't get warm enough to dry, this is another indication of an element that is not working up to power. Not getting 230 across the entire element and not getting hot enough to dry.
3) Many times when a dryer runs too long, the air flow if blocked by the vent being plugged or some plug withing the dryer itself.
Again, I am very concerned about this problem and suggest you not use it until it is repaired. If you want to check the element, it is fairly easy, but unit will need disassembled.
Mr Boo
Nov 30, 2008 | GE Dryers
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
How do you DRY with the Haier washer/dryer
Have you tried lengthening the dryer cycle or running it at a higher temp? The usual culprit for wet clothes is not running a dryer long enough or hot enough. (I remember some stand-alone dryers (coin-operated with a fixed drying time per coin) that needed two cycles to dry stuff.
Jul 12, 2008 | Haier 14.3 lb. Washer/Dryer Combo
LG DLE0332 Gas Dryer Logo
1,381 people viewed this question
Top LG Dryers Experts
jimorris77
John Tripp
John Tripp
Marvin
Marvin
Are you a LG Dryer Expert? Answer questions, earn points and help others
