SOURCE: too warm
somehow the freon has leaked out, verified by compressor running long times without stopping.
SOURCE: danby wine cooler
Is it because your keypad not functioning, meaning does the number change when you press the arrow up or down? Or when you set it, (let's say 12 Cel.) it does not reach down to that temperature. Then it could be either it's a sealed system problem( leaking refrigerant or under charge if it's a new unit). Or it could be a control problem( electronic control or sensor)
SOURCE: Danby Wine Cooler
If you are getting the E4 error code, try replacing the defrost sensor. The part might take forever to get to you, but we replaced the sensor on the wine cooler and it's working.
SOURCE: wine cooler noise
Had same problem. cooling fan was going out.Replaced fan about a year ago and now it is going out again. Am ordering another fan now
SOURCE: Danby DWC2121BLS wine cooler is
About parts check the below website and it will tell you how much the part costs.It has the exploded diagram also.
http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC2121BLS/3055/0169000/50031950/00001?blt=06&prst=&shdMod=
Yes once you take out the solenoid valve the refrigerant will escape and you need to recharge with new gas.You cannot prevent it from gas escaping.
Thank You
