My phone looks okay, powers on, looks to register, but for some reason no signal (bars) so calls cannot be received or made, carrier is Cingular (ATT). This problem just popped out of nowhere.
-   i have the same problem. phone is charged and i get the regular screen.the phone work for like 2, 3 hours but soon i got no bar.
-   Guest
Apr 20, 2009
-   charged phone with power off (normally charge with on) and now no signal-   Guest
Apr 02, 2009
-   My phone looks okay, powers on, looks to register, but for some reason no signal (bars) so calls cannot be received or made, carrier is Cingular (ATT). This problem just popped out of nowhere-   Guest
Oct 29, 2008
-   my razr doesnt have any signal.it was working fine before. it just popped out of nowhere-   bquintero444
Aug 29, 2008
-   I have the same exact problem, the phone read my sim card, it has my information it worked for a while and then all of a sudden the signal bars were gone and I can't make calls or recieve them. Also the external display just shows up whenever it wants to. -   jessica_ivon
I had the same problem with my phone- i got a cheap generic battery to replace the old one (which wasn't holding a charge for a full day, at that) and then i lost all signal, basically. I tried what scm_pa said he did - charged my old battery up, with the phone off, till the charge was complete- turned the phone on, and voila, reception!
I hope you didn't plug an external antenna into your V3. That's what I did, and have been having problems ever since. The external antenna jack is plastic and breaks easily. I can't find a replacement for that part, but I replaced the internal antenna (ordered it from cellular nationwide network for $7). Now the signal is sketchy. I can get a signal outside, but not inside the house. I think I'm getting interference from my wireless DSL network.
Hi, Having problem with Motorola RAZR V3? Main problem of Motorola RAZR V3is hardware problem.Such as won't charge, black screenetc. For solution of thesehardware problem justclick here. For any other problem of Motorola RAZR V3 like software problemor other justclick here.
Is there a way to arrange the 1-touch on my computer. I have not been able to set 7 and 8. I would...
(More)
Is there a way to arrange the 1-touch on my computer. I have not been able to set 7 and 8. I would like to see who is on what terminal and arrange them. Motorazr V3 Eddie
Everything works fine on my v3i but when I attempt to look at my drafts ,inbox or outbox the phone...
(More)
Everything works fine on my v3i but when I attempt to look at my drafts ,inbox or outbox the phone locks up completely & I have to reboot.Sometimes this clears with the inbox & outbox but not the drafts.
I copied this from another email...but it is the exact problem i have
After I flashed my Motorola V3 Razr,I can't make any calls in or out and no voice mails or text messages?
I don't believe it's the MP I put on it because I have had three different ones on there and had the same problem. Cingular service,MP setup for Cingular but can't access the web either.
Is there something I can Flash/Flex to fix this??
I'm on Verizon and I am experiencing the same problem. My wife has the same phone (bought the same day as mine) and when mine has no signal hers will have 3 or 4 bars. Another oddity of this problem is that I will have a signal, receive a call and when the call is done I suddenly have no signal.
I'm trying to find out if the battery could possibly be the cause. The reason being is that after shutting off and turning on the phone several times with no success in getting a signal I put my wifes battery into my phone and it suddenly had signal and no occurrence of my problem. Thinking the battery may be the issue I then let the battery run down to the point that the phone shut off (I do this somewhat frequently) and put it on the charger and did not turn it on until the charge was complete. At this point the problem was not occurring until my battery was down to one bar. Then the problem started occurring again. I then shut off the phone and put it on the charger for awhile. I turned the phone on and sure enough I had signal.
I may be chasing shadows with the battery theory but.....
