Question about Intel Motherboard
3.06 Ghz P4 478 HT cache SL7NA Prescott by Intel Mobile CPU
This CPU is going into my Gigabyte GA-81EXW motherboard. Will appreciate any suggestions on amount of memory to add. I am taking the suggestion of former advice and looking for 3200 and think 1 Ghz ought to be plenty to make this thing sing on most applications.
  • 94 Answers
Well it depends on what kind of operating system and applications you are using. When you're a gamer you must have a 2gb and above memory. For a Windows Xp user and for home use, 1 Gb is enough.
Posted on Aug 01, 2009
  • 23 Answers
U can add memory upto 4gb
Posted on Oct 06, 2007
SOURCE:
Ibm fru pn 49p1599
The p/n (FRU 49P1599) is a Gigabyte motherboard, their p/n GA-G8IGMIU Rev 1.1 It seems to be a socket 478 type with FSB 400 or 533MHz, Intel 845G chipset, and DDR1 memory. In the downloads section of Gigabyte's website it is not present, probably because it so old it has been removed. In this section there is the opportunity to get the manual for a motherboard and the CPU support list, amongst other downloads. A similar m/b, the G8IG model supports ONLY older Williamette and Northwood type P4 CPUs, not the (slightly) newer Prescott ones. I suspect that your CPU is not working because it is a Prescott type (or it is just broken). To check what process your CPU was made by use the program Speccy, or take a magnifying glass and examine your processor (having carefully cleaned it up) for the S-code, RK or BK number, and look it up on Intel website (ARK) or in CPU-World.
AND you should contact Gigabyte technical support (you have to go through the register rigmarole) to see they are able to answer questions you may have, get the manual and the CPU support list.
9.April.2014
Apr 10, 2014 | Intel Motherboard
Foxconn 661FXME - PC661M04-G-6L & Intel pentium 4 prescott 511 2.80 ghz
Hello you can download a manual from here:
http://www.foxconnchannel.com/ProductDetail.aspx?T=Motherboard&U=en-us0000108&Language=en-us
But BE CAREFULL when you change the cpu.
And remember to add some cooling paste.
Here is some info about the cpu:
http://ark.intel.com/products/27452/Intel-Pentium-4-Processor-511-1M-Cache-2_80-GHz-533-MHz-FSB
You will get better performance with a new mainboard/cpu
as this cpu only has one core.
Good luck
Oct 06, 2012 | Null Computers & Internet
I want to upgrade my CPU capacity from 1.2 GHZ and want to know my motherboard so much support??? my motherboard is GA-8IDX (845 chipset)
If you go to CPU-Upgrade.com, you can see all of the different processors that are compatible with your motherboard:
http://www.cpu-upgrade.com/mb-Gigabyte/GA-8IDX.html
The ones highlighted in pink are not supported for your motherboard, the ones highlighted in orange may or may not be, and all the ones in white are compatible with your motherboard. It looks like you have several high-end options, up to 2.8 GHz.
Feb 13, 2011 | Intel Gigabyte GA-8IDX 845 AGPset P4...
Gigabyte ga-81915 pmd motherboard/precott 3.6 cpu/upgrade cpu?
the best and cheapest up grade is RAM.
Make sure you have all the memory your machine can handle.
A quick look say it can handle Core™ 2 Extreme QX9770(3.2GHz,12 MB)
And it has a PCI-express slot so you have a big chiose of video cards.Are you using the machine for gaming?
Jan 10, 2010 | Intel Motherboard
Upgrading CPU
Probably nothing. If your system works, I would not concern myself greatly with this small detail. The system indicates a 3.4 GHz cpu installed. Your software may misidentify some of the features of your Prescott.
Dec 14, 2009 | Gigabyte GA-8IK1100 Motherboard
Processor compatibility
looks like you limited to the p4 Prescott, this is a p4 list of the cpu support from asus. I also looked at their bios update page and found no bios improvement. if you can move to the 775 platform ,you can move from p4. otherwise, the p4's are still  good . I had the cpu that is the 2nd one down. 3.2ghz oc'd to 3.8ghz full time with a max of 4.0ghz on air[775 platform] quad-pumped gave me a 1001.3mhz FSB
Supports Intel Prescott CPU
P4-3.20E GHz (800 FSB, L2 cache:1MB, HT, 90nm)   ALL 1006 gogo.gif
P4-3.40 GHz (800 FSB, L2 cache:1MB, rev.G1)   ALL 1011 gogo.gif
P4-3.40 GHz (800 FSB, L2 cache:512KB, HT, D1)   ALL ALL gogo.gif
P4-3.40E GHz (800 FSB, L2 cache:1MB, HT, 90nm)   2.00 1006 gogo.gif
P4-3E GHz (800 FSB, L2 cache:1MB, HT, 90nm)
SEE 4 YOURSELF
http://valid.x86-secret.com/show_oc.php?id=156822
Oct 30, 2007 | ASUS P4P800 SE (890552603657) Motherboard
Gigabyte GA-81EXW motherboard needs ram
If you plan on gaming then go for the higher priced and yes more ram will help in a gaming situation but if your just surfing and writing emails then no you don't need them,It's the timings that make ram better or not,all motherboards will do ok with cheaper ram but make sure you have the correct ram and install it in 1 and 3 or 2 and 4 they are usually colored the same
Oct 06, 2007 | Intel Motherboard
Gigabyte GA-81EXW memory chips
Any 184-pin ddr ram should work on this. You can actually use pc3200 (ddr 400) ram as well. Pc2700 ram is ddr333, and a higher speed ddr ram like pc3200 will work just as well if not better than pc2700, it will simply go down to the speed that the processor requests the ram run at. It's all backwards compatible, faster ram can run slower if the computer needs it to run at the slower speed. Depending on the price you can find as long as you get 184 pin ddr ram either pc2700 or pc3200 with work fine with your motherboard. Peter
Oct 02, 2007 | Intel Motherboard
Intel Motherboard Logo
332 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
