Question about iLO 3200 32 in. LCD Television
The fuse keeps blowing out
I replaced the fuse as suggested. Everytime I replug it to the wall socket the fuse blows. what could cause this,any other suggestions? Thanks
  • okeydokey Oct 03, 2007
    What does regulator look like, where is it located and would you know where I might get one and the price?
  • 790 Answers
You have defective power supply! you have shorted parts! like diode or regulator. replace the shorted regulator.
Posted on Oct 03, 2007
  • Anonymous Oct 03, 2007
    that is IC regulator! attached at the aluminum heat sink! from where your country?
SOURCE:
Cause fuse keep blowing
You have a short. you will need patience to route the wires from the harness to the light source, and to inspect for frail damaged wires.
Aug 16, 2013 | 2006 Toyota Sienna LE
1999 ford escort wagon my brake light fuse blows everytime i put one in
remove your tail light bulbs than put in a new fuse if it does not blow it is a bulb socket put one bulb back in check the fuse if it blows remove bulb. than put bulb in other socket if it doesnt blow with new fuse you will know what socket to replace. if this was helpful please leave feedback
Apr 12, 2013 | 1994 Ford Escort
I have a 2000 buick century and the 15A fuse for the tail lamps and dash lights keeps blowing and everytime i put a new one in it sparks and blows
i had this problem b4 check where you stick the tail light bulb in that socket for the might be burned out. i suggest checking front as well one of them probably has a bad socket
Mar 23, 2012 | 2000 Buick Century
Fuse keeps blowing.even after i replaced the cig. Lighter why
Main cause could be something stuck in the lighter socket. Sometimes, the ends of the car charger for a cell phone of GPS will separate, leaving the end in the socket itself. Placing the cigarette lighter back int he socket while there's something already in the socket will cause you to blow a fuse.
Jul 20, 2011 | 1990 Buick Century
I have an S-10 All my lights work except running lights in the rear ive checked the fuse box and everytime i replace the fuse it blows.
There is a short to ground somewhere in the wiring harness, or at the socket causing the fuse to blow.
To repair, the wiring will have to be traced front to back and insulation restored using electrical tape or shrink tubing.
Dec 19, 2010 | 1988 Chevrolet S-10
My tail lights are not working, it keeps blowing my fuse.
1.Unplug your taillights at the sockets and the front running lights from sockets.
2. put in new fuse after unplugging taillights.
3 turn on taillights if fuse blows then the wiring is grounding out somewhere between the switch, fuse panel, and rear and or front parking lights.
4.If fuse does not blow then plug in one socket at a time keep rechecking fuse. when the fuse blows after plugging in a certain socket suspect that one to be bad and replace.
Sep 15, 2010 | 2005 Infiniti G35
Fuel ECU fuse keeps blowing (30 amp)
Your fuel pump is internally binding and causing the fuse to blow. Change the pump (and filter while you're back there.)
Jun 14, 2009 | 1993 Jeep Wrangler
Radio fuse keeps blowing
make sure nothing in cig lighter socket..coins,etc..if nothing present,unplug cig lighter socket and replace fuse..if fuse doesn't blow,it's the socket causing fault..if it does,unplug radio,plug cig lighter back in and replace fuse..if fuse doesn't blow,radio is cause of fault..if it does,then ther is short in wiring
May 19, 2009 | 1992 Honda Accord
Washing machine fuse blows every couple of washes
the machine is pulling to much power.check to see if it is on a 15 or 20 amp outlet. you said you replaced the fuse. the amp size should be on it. if it is a 15 amp fuse,plug the machine into a 20 amp circuit and see if the fuse blows then. it shouldn't since it wasn't blowing everytime on the 15 amp circuit, but never put a 20 amp fuse in a 15 amp socket! the fuse can handle the load[ no pun intended], but the electrical wire would burn not blowing the fuse, thus causing a fire.
hope this helps.
wg
Feb 17, 2008 | Creda W100FW Front Load Washer
Fuse keeps blowing
Have him check power suply link, from fuse to wall plug, theres a short some where between the plug and the fuse.
Jan 13, 2008 | Kenmore 19001
iLO 3200 32 in. LCD Television Logo
163 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
