Yesterday I began noticing a 'ringing' from behind the fridge. Seems to be cooling fine in the fridge & freezer. If you can imagine a muffled alarm ringing, that is about what it sounds like. Goes about 5 seconds & I noticed 30 minutes apart this morning. Each time it makes the 'ringing' 'buzzing' noise it seems to be exactly the same & lasts the same amount of time. Any help???
SOURCE: Older subzero side by side not cooling
At sixteen years old it is almost through its life span. A change in ambient temperatures will change internal system pressures. Make sure the condenser is cleaned well. Use a vacuum cleaner to clean off the condenser, then blow it out with compressed air. Even though a condenser looks clean on its surface fins there may be dust down in between the fins.
SOURCE: Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
SOURCE: Sub-Zero 532 not cooling
Simple think I guess - just pull down a little a plastic fan blade on motor shift it will produce a powerful air flow. Fan blade should sit pretty close to the shift end. ;)
_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
SOURCE: my subzero 650 fridge part is too warm , stuck at 53 degrees
Hi There I Have a Digital Video Creator DM-4200 Video Capturewhen i was moving my cds got cracked along all others how can i get software back for a back up..
SOURCE: fridge portion of my 611 is warm but freezer is still cold. Help.
The only other thing that seems could be wrong is that your freon lines are icing up and is cause you to not cool properly. Pull out your fridge and check the compressor on the bottom
