Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
53" Panasonic HDTV showing letters and shadow
My 53" Pnasonic is only 5 years old and it has a red double shadow across the screen Pease advise.
See http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html I did this successfully on a PT-53TW53G, as per my separate post on fixya.
Posted on Oct 24, 2007
  • 790 Answers
Maybe you have defective convergence correction circuit! replace a new one!
Posted on Oct 03, 2007
SOURCE:
Picture shows double images in red and green with red and green bands across the bottom of the screen
convergence ICs need replacement there are two STK392-110 Convergence ICs in that model, Also check the 2.2 ohm 2watt resistors there are 6 of them in that model.
Jan 22, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Double image the second showing in red PT 53TW53G
replace the convergence ic's or look for loose connections that should do the job
Dec 16, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Rainbow on the screen
Do you have any larger speakers close to you tv. Or any magnets been neer it. If you unplug it for a while the tv should have remove the rainbow
Aug 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Red shadows to picture and letters on Sony TV
its most likely a warped lcd plate in the optic block if thats the correct model number which would require a optic block change out
Jul 05, 2008 | Sony KDF42E2000 42" HDTV
Red shadows and mild distortion
Hi, relasmith did you ever fix your tv kp-57ws510
thank you
Apr 03, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Sony kp-46wt500 problem with picture
i'm having a problem keeping the timer from going off and shutting the whole tv off.
Mar 20, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
53"panasonic television
UPON POWERING UP, MONITOR STAYS ON FOR APPROXIMATELY 5-7 SECONDS, THEN POWERS OFF. RED LED FLASHES 3 TIMES..PAUSES...THEN FLASHES AGAIN 3 SECS.
Jan 31, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-53TW53
more than likely its your convergence amplifier ICs and if you can solder you can repair it yourself really easy.
Jan 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
DOUBLE IMAGE
Convergence system overhaul cost about $400. No mfr. warranty after 90 days to a year unless you bought an xtended warranty for up to 5 yrs. Good set,worth keeping. Senior tech only== careful soldering needed+ OEM or better quality parts a must.
Sep 29, 2007 | Toshiba 42H83 42" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
156 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
