Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Leaking washing machine - hotpoint aquarius 1100 - wm63
My washing machine leaks, (first machine), the water was coming out from under the back, so I thought it was the inlet pipes overtightened ? But I noticed it only leaked on reaching the top of the lower edge of the door seal So the next time I tested it, I took off the top cover and could see no water, so I looked under the front and saw drips through a hole (behind the plastic clip on cover at the base of the machine) coming from the very lowest part of the door, inside the machine shell, leaving a puddle on the floor. I assume this is the seal on the door ! If you also think so, is it an easy job, or one for a plummer. Can anyone buy the parts and fit them ? Thank-you, Rob.
  • 209 Answers
Water leaks are very hard to locate as the water always drips from the bottom, it is just a case of detailed looking, after a while there will be a dry white mark where the water has dried out, this will show where the leak originated from, there are a few things at the front of the machine that it could be, sorry can't help much more nearly all parts can be bought by the public and with common sense and taking very detailed notes where wires came from etc, most jobs can be done by a competent diy person with basic electrical knowledge remember water and electric do not mix always unplug from power supply where working on any appliance
Posted on Oct 03, 2007
SOURCE:
Hotpoint Aquirius 1100 - WM63 Hi, A leak has sprung from my washing machine and being fairly capable I've already had the sump off cleaned that out and re- attached it and checked the door seal for...
Hotpoint Aquirius 1100 - WM63 leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 31, 2011 | Hotpoint Aquarius WD63 Front Load...
How to take bearing out of aquarius model wm63
The information for dismantling and rebuilding a Hotpoint WM washing machine is all in the workshop manual including wiring connections
Mar 17, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius 1100 WM63 Not Spinning Clicking Programmer
I would suggest you check the brushes in the motor, as it sounds like they are worn out.
Replace them if they are less than 3 or 4 mm long
This would give you the symptoms you are describing.
Please rate my solution.
Thankyou.
Feb 09, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Aquarius 1100 wm63 very noisy spinning
Remove rear cover of washer.
Remove drive belt.
From inside the drum, spin the drum by hand, if it is noisy or feels rough, then main drum bearings have failed.
If no noise, then possibly motor bearings noisy.
Hope this helps Thankyou.
Nov 27, 2009 | Hotpoint Washing Machines
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WF210 Front Load Washer Leaking This video will show you how to find that leak on any front loading washing machine
Apr 01, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint aquarius wm63
The heating element for this paticular model is located on the front casing of the drum.. you have to remove the front panel complet with the door and you will see it at the bottom behind a black protective cover.
Nov 27, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Aquarius 1100 WM63
some times when there is no motor action people think the machine has stuck try a set of brushes you must diconnect from the electrical mains first if unsure call an expert you can not put a price on safety
Oct 08, 2006 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
518 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
