Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Projection lamp indicators
What are the indicators for a projection lamp failure? Ten months ago the green lamp indicator blinked a series of five times and then cycled through the six again -I thought it was an indication of a projection lamp but it turned out to be a board component failure. Now the green light starts blinking and then turns into a bright light. What are all of the indicators of a projection lamp failure? Thanks
  • 790 Answers
Maybe you have lost contact at the lamp circuit! check the CRT circuit and the lamp circuit!
Posted on Oct 03, 2007
SOURCE:
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
Kf-60xbr800 indicator blinks 5 times
5 indicates lamp ballast failure p/n 1-468-510-15 . but thats not always correct. sometimes the tv doesn't detect it correctly and it's just the lamp XL-2000U p/n A-1601-753-A .
Sep 28, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
When turning power on, nothing happens and then it blinks red five times in a row. KDS R50XBR1
The five blinks indicates a lamp driver failure. The lamp driver is commonly called a ballast. Odd thing is that these set rarely have ballast failure. But the microprocessor in your set thinks the ballast is defective and is rendering the five blink code.
Jul 09, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony Grand Wega 60" indicator lamp blinks 5X green then 6 red
It is unusually to see BOTH of these flash codes together. I have never seen them at the same time. A 5 flash is a lamp driver error, which is possibly related to your lamp failure. You may have to replace the lamp driver or "ballast" to correct this problem. The 6 flash is a power supply problem and more serious, as it will likely take a technician to narrow down exactly where the fault lies. It may be a thermal fuse open OR a failure in the power supply itself. What was the original symptom that caused you to replace the lamp? Did you use an original Sony lamp as a replacement?
Nov 27, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Green screen
sound like a DM or FMT board failure. this is not the 4 cap blinking green light problem. check out
www.tv-techs.com
Nov 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sharp 56DR650 shows power but wont turn on, Sometimes it turns on
That's error code 32. Indicates lamp trouble or failure. The system will shut down automatically.
Aug 29, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
POWER/STANDBY indicator flashes five times
5 blinks means lamp driver error. I would suggest replacing the lamp.
Jun 06, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
My lamp indicator is blinking green
If you believe the book it means that the lamp cover is not closed.
Dec 26, 2007 | Zenith E44W46LCD 44" Rear Projection...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
204 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
