Question about Lexmark Optra SC 1275 Laser Printer
Lexmark printer error at power up
I am getting a message at power up that says ( 84 pc life exhausted )
  • Anonymous May 27, 2008
    I have a Lexmark sc1275 that won't reset maintenance, after going to registration and pressing the right arrow it immediately starts a color check and freezes in that spot. Any suggestions to clear.
    Steve
A few months ago, I received the same message. This indicates you need to replace the Photoconductor (Drum) ASAP. An interim solution is to replace the fuse on the photoconductor cart. until you've replaced the unit. Remember, the unit will eventually wear down and your prints will be show some stripping.
Posted on Jul 10, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Lexmark Master
  • 1,362 Answers
Pc stands for photoconductor or print cartridge or in layman's term toner
the toner has reached its expected life or toner has ran out
Posted on Oct 15, 2007
The photoconductor is seperate from the toner carts
Posted on Mar 18, 2008
Error code 84.32
Error 84 Transfer
Drum
Exhausted
The Transfer drum has reached the end of it's life and must be replaced. May require service technician
Press "GO" to clear message and temporarily continue
Jul 14, 2014 | Lexmark E360DN LASER PRINTER N Laser...
Replace pc unit problem on Lexmark W840 Laser Printer
Here is an excerpt I found from the W840 user manual. Looks like you need to change the photoconductor kit. Here is the link for the user manual: images.lexmark.com/publications/pdfs/w840/eng/ug.pdf
To ensure print quality and to avoid damage to the printer, the printer stops operating after the photoconductor kit has reached approximately 60,000 pages (Letter/A4). The message 84 Replace PC Unit is displayed when the printer reaches this point. If the Toner Alarm setting is set to Single or Continuous (default is Off), the printer automatically notifies you before the photoconductor reaches this point and displays the message 84 PC Unit Life Warning. To avoid having the printer stop operating, replace the photoconductor kit when you first receive the 84 PC Unit Life Warning message. Once the photoconductor kit has been replaced, normal printer operation resumes
Apr 11, 2011 | Lexmark W840 Laser Printer
We are receiving the error message "84 oc life exhausted". What can we do to solve?
84 PC Life Exhausted indicates that the photoconductor unit has reached its functional life. The photoconductor kit will need to be replaced. The printer will not function so long as the Exhausted message remains on the display. The only way to clear the message is to install a new photoconductor. After replacing the photoconductor unit, you need to manually reset the pc page counter as well. Thank you for choosing Lexmark.
Sep 01, 2010 | Lexmark Optra SC 1275 Laser Printer
84 TRANSFER BELT EXHAUSTED
84 TRANSFER BELT EXHAUSTED indicates that the transfer belt is exhausted and must be replaced. A new transfer belt must be installed to clear this error message. For assistance, you can contact Lexmark technical support or your authorized service provider. Thank you for choosing Lexmark.
Aug 31, 2010 | Lexmark Optra C710 Laser Printer
What shoud I do when error 84 replace
Photoconductor is the part of the printer where the image gets created this is a very delicate and important part in the Laser printing process. If you open the printer and remove the toner, you should see it sometimes is like a green or blue color. The message 84 is just telling you that the photoconductor has reached the end of life and needs to be replace. Here is also a link on how to do the replacement http://bit.ly/bn2HFc
Jan 30, 2010 | Lexmark X342n All-In-One Laser Printer
My printer lexmark e352 shows an error code 84 replace fotoconductor unit. How to reset this error code
The above error code refers to :-
Hope i helped you.
Thanks for using "Fixya".
Jun 23, 2009 | Lexmark E352dn Laser Printer
Replace photoconducter 84 on lexmark e350d
Go to www.lexmark.com Select the correct country. then Selectg "Technial Support" Enter the model of your printer "E350D" Click on search. Under the "Knowledge base" header place this number into the search bar: "ENUS27198" click on search. ************************* Lexmark E350d Country / Region: United States Language: English Need to download a driver? How to Reset the Photoconductor Page Count on a Lexmark E350d or 352dn Printer ID: ENUS27198 Procedure Follow the steps in the table below to reset the photoconductor (PC) page count. NOTE: The directions in this article are in English. To download a PDF file containing these instructions in several other languages, click here (file size: 782 KB). Step Action 1 Enter the printer's Configuration menu: Power off the printer. On the printer's operator panel, press and hold the select button () and the back button (). Power the printer back on while keeping both these buttons held down. When you see the messages Performing Self Test or Busy on the printer screen, you can release both buttons. If the printer has successfully entered configuration mode, you will see a new menu with the heading CONFIG MENU at the top of the screen. 2 Press the right arrow button () until you see Reset PC Cnt. Press once. You will see Reset. Press again. The printer will display a Resetting PC Count Value message and go back to the previous screen. 3 Press once. 4 Press or on the operator panel until you see Exit Config Menu. Press once. Selecting this will cause the printer to reboot. If the counter has been reset correctly, the printer should return to a Ready prompt. 5 If this does not clear the PC Life Warning or Replace Photoconductor message, power off the printer and attempt this entire procedure again. If the error remains after two attempts, confirm that: The correct photoconductor unit is installed. The part number on the photoconductor unit should be E250X22G. If it is not, install the correct photoconductor unit into the printer. The photoconductor unit has not been refurbished by a third party or is not damaged in any way. If the photoconductor unit was refurbished by a third party or appears to be damaged, try replacing it again before seeking service on the printer. If the error persists, the printer may require service to correct the issue. Contact Lexmark Technical Support for more information. Don
Jun 03, 2009 | Lexmark E350d Laser Printer
Lexmark c510 error message ;83 photodeve cart missing
See User Reference
http://www.lexmark.com/publications/pdfs/c510/eng/userref.pdf
Understanding printer messages
pages 184 and 185
"Message:
83 Photodev Cart Exhausted
What this message means:
The photodeveloper cartridge is completely used.
What you can do:
Replace the photodeveloper cartridge.
See also: Replacing the photodeveloper cartridge [page 73]
Continuing below
Message:
83 Photodev Cart Life Warning
The photodeveloper cartridge is nearing the end of its life.
What you can do:
• Press Go to clear the message and continue printing.
• Replace the photodeveloper cartridge.
Continuing below
Message:
83 Photodev Cart Missing
The photodeveloper cartridge is either missing or incorrectly
installed.
What you can do:
Correctly install the photodeveloper cartridge to clear the message and continue printing.
See also: Replacing the photodeveloper cartridge [page 73] "
Nov 26, 2008 | Lexmark C510 Laser Printer
Error code Lexmark Optra 1275 Printer - 84 PC Missing
Usually there is more to this message particulary if this is a color printer. Basically the printer is telling you that tyhere is a problem in the Photoconducter area of the print cartridge. Normally I would expect to see a 84 PC end of life. Can you tell me if you left some information out, please?
Sep 03, 2008 | Lexmark Optra SC 1275 Laser Printer
Lexmark Optra SC 1275 Laser Printer Logo
307 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
