Question about Electrolux 18 in. ESL4114 Slim-Line Built-in Dishwasher
Eloctrolux dishlex 302
Hi Have no instruction manual and am unable to get the drying cycle to use heat. The light indicators shows red on this cycle any solutions Carol
  • Ange C Jun 28, 2008
    I too have the same problem, i am thinking maybe it could be the heating element cant find anything in my manual to explain what to do or if its easy to fix or do i need a professional
  • Anonymous Mar 30, 2014
    dishlex 302
    Habit-Forming:
  • 59 Answers
You can download and view the manual HERE
You will need Acrobat reader to view this.
Posted on Feb 05, 2008
  • Artur Rzasa
    Artur Rzasa Feb 05, 2008
    Also, make sure it's not running on ECO mode if it has one as that usually doesn't use the heating function to preserve power.
I have no manual for a REX dishwasher Model TT9E. Could you give me a brief indication of what each wash cycle does, since I want to find one that 1. does not use a heated drying cycle 2. does not...
Hi thearbours ,
Plz try this link: http://safemanuals.com/brand-user-guide-instructions-owner-manual/REX
Hpoe it works if not plz revert
Aug 22, 2011 | Dishwashers
I have a dx302. its not heating the water or drying.
download this manual...
http://epubl.luth.se/1402-1617/2006/118/LTU-EX-06118-SE.pdf
Aug 22, 2008 | Electrolux 24 in. EDW5505EPS Stainless...
No drying cycle on the electrolux dishlex 302 any idea's
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Nov 10, 2010 | Electrolux 18 in. ESL4114 Slim-Line...
Hi, My Dishlex dishwasher DX 302WB ia showing 10
check this
1)blockage in boiler tank.(cleaned)
2)water pressure is less.(check solenoid filter)
if it's programmed in timer mode within the period it must reach the water level in the tank due to this also it may happen.
Jan 06, 2010 | Electrolux Dishwashers
User manual for electrolux dishlex DX302
Go to http://www.dishlex.com.au/SupportCentre and then search by the model description DX302WB. I downloaded a pdf file no problem.
Nov 12, 2009 | Electrolux Dishwashers
Dishlex dx 403 does not dry dishes - fan dry on red led
Ther have been a lot of complaints about the drying performance of these machines. One solution suggested by Electrolux is to use the "anti bacterial" wash mode, as this is a higher temperature wash, therefore dishes dry better. If you are using Eco wash or Quick wash, drying performance is not very good- Electrolux recommend leaving door ajar at end of cycle to improve drying. Also, ensure your Rinse Aid compartment is topped up, as Rinse Aid greatly improves drying performance.
-Please note: these dishwashers will not dry plastics and other items that do not hold the heat very well!!
-Also, you should be able to hear the drying fan running at the end of cycle- if not, then you may have faulty fan (uncommon), or control board (more common).
Good luck!!
Aug 12, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
The dishlex 302SB is not producing hot water for the washing
I have a Dishlex 302 which had this fault. Initially I thought it was the inline heater element and replaced it. It seemed to work but later no hot water again. Someone here put me on to the problem. There is a dry joint in the control board in the top of the door. This controls the relay which powers up the heater. Unplug it from the mains (very important) and undo the screws around the top of the door (don't take the door right off!) you will be able to wiggle off the front panel containing the electronics. The control board is ealiy disconnected an removed from the machine in its protective plastic cover. Have a look around the PCB and you will see the dry joint. Resolder with rosin core (electronic) solder, reassemble and you should have hot water.
May 23, 2009 | Electrolux 504199 Dishwasher
Dishlex 302 SJ dishwasher on quick cycle beeps and shows 20 ...?
THATS GOOD NEWS AND YES IT IS THE TIME LEFT IN YOUR CYCLE HAVE A GOOD TRIP
Apr 11, 2009 | Dishwashers
Vulcan dishlex 750 eco taking alot longer to complete wash cycle.
How is the water flow into the machine. Are all your inline filters clean?
Apr 05, 2017 | Dishwashers
Dishlex dx 302 heat drying
Found I had no hot water in my Dishlex DX302 and did a google search and found this page.
My problem was found to be the same as the others; one of the solder joints on the relay on the control board had arced off.
You could see the burn mark on the board and cover where it had been arcing.
Soldered it back together, and now it seems to be going good again.
Now my only problem is a damaged door seal, which means a small water leak; I have used part of a rubber glove to bridge the gap, and it reduces the water leak.
Sep 22, 2007 | Dishwashers
Electrolux 18 in. ESL4114 Slim-Line Built-in Dishwasher Logo
935 people viewed this question
Top Electrolux Dishwashers Experts
Mike
David Baisa
Hjalmer Lamminen
Hjalmer Lamminen
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
