First thing to do is find the temp in the bucket. Should be between 10-15 degrees. If its colder then try turning the thermostat to a warmer setting. If its warmer than this then the unit is not getting cold enough. Look at the cendenser to make sure that its clean. If thats good you might have to check the thermostat. (if its 10-15 deg) Check the wiring. red goes on terminal1 yellow on 2 and blue /black on 3. The control might not be switching to harvest position. Wait until you hear the compressor and fan shut down then look at the icemaker. If not advancing then replace the thermostat.
the water is dripping from the drinking water place. I need to know how to remove the front panel to...
(More)
the water is dripping from the drinking water place. I need to know how to remove the front panel to be able to see inside, or to replace anything broken or cracked.
Ice cube rakes dont have enough power to push ice out of tray. could it be the mold heater is not...
(More)
Ice cube rakes dont have enough power to push ice out of tray. could it be the mold heater is not heating up to release them?
