Question about Panasonic CT-36D32 36" TV
Panasonic screen problems
First, several months ago one channel was usually just a zig-zag pattern which I could access by using the VCR. Next, several channels (sometimes all) would change to snow for a short time or long time. By turning off, then on, the picture could be restored. Then recently, these additional problems: 1. The picture cannot be restored by turning off then on. 2. Sometimes, several channels will have the same picture. 3. Sometimes several channels will have the same ghost-like picture. I have plans to upgrade to digital during the coming January sales, so need some inexpensive, stopgap measure to get me by until then. Thanks.
    An expert who has answered 500 questions.
  • 556 Answers
Re: Panasonic screen problems
Then recently, these additional problems: 1. The picture cannot be restored by turning off then on. 2. Sometimes, several channels will have the same picture. 3. Sometimes several channels will have the same ghost-like picture. the above all problems are due to one that is weak signal. 1 check for antena or cable or satellite input is ok or wire might be defective due to old. 2 input socket is loose some where. 3 loose contact near tuner or some print break. 4 at last & final its tuner might be defective. hope this will help.
Posted on Oct 06, 2007
0 characters
3 Points
Tuner appears to be stuck in channel 4. Cannot change Channel.
It is a tuner selector problem, either the processor controller ic is the problem, or the selector ic. The easiest solution use a VCR as your channel changer, and check to make the VCR is set to channel 4.
Jan 03, 2011 | Panasonic CT-27SL14 27" TV
I have a problem with my Panasonic CT-27SX12 27"
On remote you must push the TV button first then the on button to activate or deactivate the TV. Channel or volume on the TV does not need to select anything on remotes.
Nov 18, 2010 | Panasonic CT-27SX12 27" TV
My Panasonic Omnivision TV won't change channels...
just press Stop/Eject Rew/<< buttons (Action) to get setup menu
Sep 01, 2008 | Standard (CRT) Televisions
Small number in corner Panasonic TC 63A61
If you cannot get the original remote or a more compatable aftermarket remote, you might try hooking up a VCR or Cable box to the auxiliary audio/video jacks and use that input while changing channels with the VCR/cableBox.
Aug 02, 2008 | Standard (CRT) Televisions
Just want the Orion TV (Model: STV 2763) to play VHS videos
Problem Solved:
Take your connector with the 3 colors red,white & yellow and plug into VCR OUT. The other end (w/ 3 plugs) goes into the INPUT on the back of the TV. Next insert a VHS Tape & search the TV for input or a channel below #2 for Cable#1,2,3 or AUV Channel.
In this case; Channel AUX #1
Shows / Plays Video w/ clear sound & picture.
May 21, 2008 | Orion STV2763 27" TV
Sanyo TV
I too just bought an RCA remote for the same television. The button to access other video screens is the A/B button on mine (next to the last channel button).
Jan 08, 2008 | Standard (CRT) Televisions
Hitachi screen goes snowy and sound is totally distorted
Sounds like bad solder connect in tv tuner....can usually be
repaired or replaced.......................T.
Nov 30, 2007 | Hitachi 43FDX01B TV
White horizontal, zig-zagging lines
It sounds to me like you're describing the re-trace of the unit. It is repairable, and more so the sooner you get it to the repair facility.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-27FS120 27" TV
My phillips ts2746c221 model
If it is a horizontal line is straite or zig zag, if it is straite then problem in your vertical section,please check the supply of vertical section or output ic of vertical, if it is zig zag line then it could be dry solder in the yoke connector or vertical yoke open, please let me know the vertical ic no.
Oct 22, 2007 | Philips 27PT71B 27" TV
My Panasonic TV
Many TVs, including some Panasonic models, have an Auto-OFF feature that will automatically turn the set off after a few minutes, if the TV thinks it is not receiving a video signal. By reinserting the coaxial cable, you are probably restarting the Auto-OFF timer inside the TV. There are several possible things that could cause the Auto-OFF to falsely activate. Try and change the coax cable going from the VCR to the TV, if you have a spare. If not, plug the cable from the cable box directly into the back of the TV. Make sure the TV is on the correct channel, usually Ch 3 or Ch 4. (Do not use the original cable that was running from the VCR to the TV, just in case it is intermittent.)
Sep 07, 2007 | Panasonic CT-36D32 36" TV
Panasonic CT-36D32 36" TV Logo
90 people viewed this question
Top Panasonic Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Panasonic Standard (CRT) Television Expert? Answer questions, earn points and help others
