Question about Mitsubishi WS-65869 65" Rear Projection Television
Mitsubishi WS-65819 2002 rear projection
When you turn the tv on there is no picture on the antenna a or b channels sometimes there is audio other times its all just snow noise but no picture. this last for somewhere between 1 min to 5 min and then the picture comes on. sometimes it will go on and off during this time. If you use an input such as a dvd or any other not utilizing the antenna a or b input the picture comes right on no delay at all. WE usually watch a dvd while waiting for the antenna inputs to work. tried a/v reset and turning power off. Perhaps its a input problem. i did take the screen off and dusted and removed cobwebs from circuit boards but no luck. what do i look for for ?
  • 1 more comment
  • 65819 Oct 03, 2007
    anyway to isolate any of these solutions. voltage check visual or just try a new one?
    The tv works fine after you let it "warm up"
  • 65819 Oct 11, 2007
    i opened the back and found that if i jiggle the metal boxes after the antenna modulator the picture comes on.  The piece Im looking at is after the metal piece that the antenna cable hooks to.  it attaches to the rf modulator and then goes to the circuit board. I moved the piece back and forth and it is was working good but then the other day it started doing it again.Is the electical piece bad or is the solder joint just loose to the board?  Thanks for all the help
    Genius:
  • 1,694 Answers
1)possible bad RF modulator (the small box the A or B signal first goes thru) 2)Bad tuner (mounted on signal board) 3)or missing voltage to run tuner You could replace signal PCB,but that gets a little pricey.
Posted on Oct 03, 2007
  • Vista Electronics Oct 03, 2007
    From a cold start,gently tap on tuner to see
    if problem cuts in/out.
    Many of my customers do not use antenna inputs==
    preferring component video,s-video or composite video for superior performance.Generally called
    a tuner by-pass==saves money to be spent elsewhere.!!
Mitsubishi Rear Projection TV Model WS-55311
Rear projection TVs are dinosaurs. Sell it if you can get anybody to buy it and get an HDtv they're pretty cheap now not to mention thinner, lighter and better for your eyes. Imagine the space you'll save if you mount it on the wall and the cost of electricity. Not trying to be a jerk but it's time to move into the 21st century. The picture is waaaaay better.
Apr 06, 2014 | Mitsubishi WS-55819 55" Rear Projection...
There is not reception. Antenna A failed a year a go, I switched to Antenna B and now is not working either. When I connect Cable (COX) antenna inputs, A & B, do not detect it. My TV is a Mitsubishi...
Check if the video /audio input( AV) works ok.If so the tuner inthe set is defective and must be replaced.
please replace one to confirm after checking the +B voltage on the tuner being present.
Sep 12, 2010 | Mitsubishi WS-65513 65" Rear Projection...
Can't seem to add HD channels to Mitsubishi WS-65513
You need to run an external antenna feed to the air DTV input jack, bottom left. You can use your loop out if you already have an antenna connected to your antenna A input jack. Create a DTV device, then run your antenna setup for DTV.
Mar 14, 2009 | Mitsubishi WS-65513 65" Rear Projection...
No Audio with HDTV on Mitsubishi WS 55859; no problem w analog tv
Have had bad exprience with RCA converter boxes. The box will lose audio and has to be turned off and then back on. You may want to hit mute during this process, the volume varies from analog to DTV. If you have no problem with analog audio I would look into a different converter box.
Feb 22, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Great Picture But No sound
Good Day;
Look in owners manual pages 28-35, pay special attention to page 31 and make sure the antenna is connected to ANT-DTV input. Good Luck, big IRISH.
Sep 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Picture black out
Like your computer a tv has the same type of circuits, & sometimes they get glitches, maybe, but i feel you might be starting to have a problem in the 'DMD" board in your tv. Maybe not; unplug tv for 10 min to 24 hrs. I am a mit factory auth tech. good luck,.
Jan 05, 2008 | Mitsubishi WS-55311 55" Rear Projection...
Help with my mitsubishi 65 inch tv
convergence ic going. you may also want to check some caps;
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
caps
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Dec 12, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-48613
Did you try reset? Unplug AC cord for a while,plug in try again...
2) With paper clip, activate reset thru access hole on front of
TV ( consult owners manual) recheck.....................
3) Leave set unplugged from AC overnight.................T.
Please rate this solution........................
Nov 11, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
120 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
