Question about Compaq Armada E500 Notebook
How to save a document on a floppy disk
How do I save a document on a 3.5 floppy disk so I can retreive it from another computer?
Re: how to save a document on a floppy disk
After a long search, I finally found the CMOS battery of my Armada E500 where I was expecting it the least: under the power buttons bar, attached to...guess what...the inverter!
Posted on Oct 06, 2007
    Problem Solver:
  • 18 Answers
Close the file, right click on it, select send to, click on a drive
Posted on Oct 03, 2007
0 characters
3 Points
How to reset bios password
Restart computer with bootable system disk in floppy drive. This should give you access to BIOS setup screen (using DEL or F1 key). Change BIOS password and boot order, save to BIOS (F10) Remove floppy disk and start computer.
May 21, 2013 | PC Laptops
Back up FAVOURITES from internet explorer
Step 1
Insert a blank disk into the floppy disk drive (or other removable disk drive).
Step 2
Double-click My Computer.
Step 3
Double-click the hard disk icon (usually C:).
Step 4
Double-click the Windows folder.
Step 5
Right-click the Favorites folder and choose Send To from the menu that appears.
Step 6
Select 3 1/2 Floppy (A) or the drive containing the blank disk. The favorites file is copied.
Step 7
Remove the disk from the drive.
Step 8
To use the favorites on this or another computer, drag the Favorites folder on the disk to the Windows folder on the computer.
on Feb 08, 2010 | PC Laptops
Need the manual for hp pavilion notebook dv7-4008ca & downloaded
HP Support > Pavilion dv7-4008ca Notebook PC > Main Support page,
Click on Manuals in the list.
Click on -
HP Pavilion dv7 Entertainment PC - Maintenance and Service Guide
,for a Service Manual.
Click on -
Notebook PC User Guide - Windows 7
,for a User Manual
These are PDF files.
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the manual file name you want, it may take up to 30 seconds before the first page comes up.
(Just wanted you to know while you are staring at a blank screen.
The file is downloading to your computer)
The download is a Temporary download. Once you close the PDF file, you have to go back, and download it again, to see it.
At the top right of the top header is a Floppy Disk icon.
It is the third icon from the left. If you hover your mouse cursor over it, Save a copy, will be briefly revealed.
Click on the Floppy Disk icon.
In the Save File box look to see where the file will download to.
Desktop: Goes to your desktop screen.
Documents: Goes to your Documents folder
Downloads: Goes to your Downloads folder.
You can click on the blue Down Arrow to the right, and in the list click on where you wish the file to download to.
I put them in my Documents folder.
(Actually I am running WinXP right now, so they go to my My Documents folder. Win Vista, and Win 7 it's -> Documents)
In the File name: box below, write down the file name.
Click in this box, and type what you want.
(Pavilion dv7 User Manual, or Pavilion dv7 Service Manual?)
Now go below, and click on Save File. (OK?)
From there put a new CD-R disk in the optical drive (CD/DVD drive), and then Right-click on the file name. Click on Copy.
The reason I do not just directly copy to disk, from the HP PDF file, is if there is a problem I want to have the file handy. I can start over.
(After checking that the disk has a good copy on it, you can then delete the file from the computer you downloaded it on, and save harddrive space on that computer)
For additional questions please post in a Comment.
[Service Manual? Would be interested in what the problem is]
Oct 13, 2012 | HP Pavilion PC Laptops
Hello, good afternoon if you can help me please with this: I tried to format with the information Sean Tech has to do it from the bios but when you get to step 4 tells me that the cd is not bootable on...
1) SeanTech gave a solution for this back on January the 8th, 2009, to a hardik_1985.
Nice that you remembered him if this is you.
2) I agree with your wanting to perform a complete reinstall. Programs like Tune Up 2010 are a bunch of junk anyway.
They're supposedly designed to help the user save steps, but are there just to grab your money, in reality.
You can do the same things by yourself without the program/s.
3) Your start-up configuration needs to be CDROM, Hard Disk Drive, then Floppy Disk Drive.
This will force the computer to boot from the disk in the optical drive. (CDROM)
Go into BIOS Setup, and change it.
After you have moved CDROM to the top of the list in Boot Order, (Or Boot Configuration), make SURE you save changes, or it will be like you have done Nothing at all.
Press the F10 key to save changes, then highlight Yes, or Y, and press the Enter key.
Put O/S disk in your optical drive tray. Restart the computer.,2817,1386949,00.asp
Dec 16, 2010 | Sharp Actius RD3D Notebook
Describe your sony vaio PCG-C1VRX/K Problem: O/S not found...cannot enable usb/cd use to fix/load new O/S
What do I do if the message "Operating system not found" appears when my computer starts, and why won't Windows start? ? Make sure the computer does not have a "non-bootable" floppy disk in the floppy disk drive (if applicable). ? If a non-bootable floppy disk is in the drive: 1. Remove the floppy disk. 2. Restart the computer and confirm that the Microsoft® Windows® operating system starts properly. ? If Windows still does not start, follow these steps to initialize the BIOS: 1. If there is a disk in the floppy disk drive, then remove it. 2. Turn off the computer. 3. Remove any peripheral devices connected to the computer. 4. Restart the computer. Page 1475. Press F2 when the VAIO logo appears. The BIOS Setup window appears. 6. Press the Right Arrow key to select the Exit menu. 7. Press the Down Arrow key to select Get Default Values. The message Load default values for all SETUP items appears. 8. Press Enter. The Setup Confirmation window appears. 9. Select Yes, and press Enter. 10. Select Exit (Save Changes), and press Enter. The Setup Confirmation window appears again. 11. Select Yes, and press Enter. The computer restarts. What do I do if my computer stops responding? Why can't I turn off my computer? It is best to turn off your computer using the Turn Off Computer option on the Microsoft® Windows® Start menu, located on the taskbar. Using other methods, including those listed below, may result in loss of unsaved data. ? Click Start on the Windows® taskbar, select Turn Off Computer, and then click Turn Off. ? If your computer does not turn off, press the Ctrl+Alt+Delete keys simultaneously. When the Windows Task Manager dialog box appears, click Turn Off from the Shut Down menu. ? If your computer still does not turn off, press and hold the power button or slide and hold the power switch until the computer turns off. ? If your computer stops responding while playing a CD or DVD, press the Ctrl+Alt+Delete keys simultaneously. You can turn off the computer from the Windows Task Manager. Pressing the Ctrl+Alt+Delete keys simultaneously or turning off the computer with the power button or switch may cause loss of data. ? Remove the AC adapter and battery.
Dec 13, 2010 | Sony VAIO PCGK45 PC Notebook
I bought a used T30 so I don't have the instructions. I can't get my arrow pad to work. I can move the arrow but when I click on something I have to use my mouse?? Is there a way to activate so I can...
debiplow401 what if I give you the instructions?
ThinkPad T30 Setup Guide.
(How to;
1) Set up your computer
2) Turn on the system
3) Use the TrackPoint pointing device
4) Volume button controls
5) Access ThinkPad
Click on the first file listed -
t30engsq 62p9239.pdf.............English - Setup Guide for ThinkPad T30
This is a PDF file. Takes a few seconds after you click on the file name to see the first page. Also takes additional time to fully download. Suggest letting the file fully download before looking through it, or saving a copy.
If you are aware of the following please disregard;
1) The box to the right of the blue Down Arrow is the page number box.
If you know the page number you wish to go to, you can;
A) Put your mouse cursor in the box, Left-click once
B) Type the page number
C) Press the Enter key
Much faster than using the Down Arrow.
The + sign in the top header is the Zoom In icon.
The - sign is the Zoom Out icon.
Most of the time the file will be downloaded in a too large view for readily viewing.
To save a copy:
You can save a copy to a CD disk.
This way you can delete it from your computer, and save Harddrive space, and have the file anytime you wish.
Left-click on the Floppy Disk icon.
The Floppy Disk icon is in the top header, and is the second icon from the left.
If you hover your mouse cursor over the Floppy Disk icon, it will briefly reveal,
"Click to save this file to your computer or another location"
After you click on the Floppy Disk icon a small window will come up.
Save a copy...
At the top of the Save a copy window you will see a box with - Save in: to the left.
In the box is stated where the file will download to.
I would put the file in My Documents.
Click on the blue Down Arrow to the right of the box, then click on My Documents in the list.
Down at the bottom of the Save a copy window is the File name: box.
You will see - t30ensq_62p9239.pdf in the box.
You can add to this file name to make it easier for you to find.
Put your mouse cursor in the box right after the f in .pdf
Left-click twice.
Type ThinkPad T30 Setup Guide.
Now go to the bottom of the Save a copy window, and click on Save.
To find, and open the file:
Click on Start> Double-click on My Documents > Click on the file name
You may wish to have this also,
ThinkPad T30 Service and Troubleshooting Guide -
Click on the 4th file down,
T30engstq 67p4720.pdf.............English - Service and Troubleshooting Guide for T30
This is a PDF file.
You can save this to CD disk also.
Oct 22, 2010 | IBM ThinkPad T30 2366 Notebook
How to format acer one laptop without cd-rom?
Use an external CD rom or sometimes there is a petition file in the Hard drive to format.
Oct 19, 2010 | Acer Aspire One PC Notebook
How to format a Toshiba M100
get a win 98 boot disk floppy. set bios to read floppy or usb floppy first save and exit. insert disk and boot comp. select boot without cd rom support. At command prompt type " FDISK " then hit enter dont type quotes. delete the particians then create new partician set 1 particians as active then remove disk then insert OS disk and go forth. I after you install your new OS and you get two boot options at the command promt after loading type " delpart " and delete the particians and save (use the tab and alt keys to bring up menus save and exit before you leave delpart) reboot and run fdisk to creat a partician and set it as active. then load your OS
Jun 10, 2009 | Toshiba Satellite M100 Notebook
see the back of laptop there is an icon of RAM open that sckrews and put off the cover,
May 09, 2009 | HP Compaq Evo n620c Notebook
Computer problem, help.
This generally indicates a hard drive crash/failure, in which the hard drive will need to be replaced. Rare, but occasionally you will get this error from an operating system glitch. Before you run out and buy a new hard drive, try reloading the operating system. If you have any problems during or after the install, then the hard drive is shot.
Jul 01, 2008 | Sony VAIO FRV25 Notebook
Compaq Armada E500 Notebook Logo
103 people viewed this question
Top Compaq PC Laptops Experts
John mullen
 Mike M
Mike M
Are you a Compaq PC Laptop Expert? Answer questions, earn points and help others
