Question about Zenith IQC50H94W 50" Rear Projection Television
Zenith IQC50H94W Color Loss
Experiencing color issues. Took the back off to find the blue tube not working. Is it worth replacing and if so, where do I find a tube? The TV was free, so because of this so I have no problem tossing it.
  • 790 Answers
Check the 180 volts that is the supply of the CRT Grid.
Posted on Oct 03, 2007
I am unable to adjust the red color in the convergence adjustment on my IQC50H94W 2000 Zenith 50". From everything I read I believe I need to replace my Convergence IC Chips, however I am not 100%...
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 24, 2011 | Zenith IQC50H94W 50" Rear Projection...
My projection tv lost its blue tint
Hi
Thanks for using FixYa. Usually this happens when the Light Engine has gone bad, and I should say this is a common issue with Projection TVs. There are three tubes/mini LCDs inside your TV- green/yellow, blue and red. When the set heats up over time of usage the screens tend to break resulting in leaking color everywhere. The cost to get this fixed by a professional should be around $300 depending on the parts that needs to be replaced. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 23, 2010 | Zenith E44W46LCD 44" Rear Projection...
RED, BLUE COLORS DONT WORK
two components are concerned for that type of action,
i a tube plays apart
ii on the neck of a tube, are three transistors for colors
iii color producing IC
the work is quite much take your tv to a shop, its not difficuilt to repair but involving, thanks
Mar 26, 2009 | Televison & Video
I have a Zenith Projection 50" TV IQC50H94W that has a blue arc
You need to replace your STK392-150 I.C.'s, Also, check all of the large nearby resistors, make sure none are burned, and remember, you have to check the resistance out of circuit with a meter.
once the resistors are checked, and the convergence I.C.'s replaced, you should be able to converge the picture through the user menu.
Dec 18, 2008 | Zenith IQC50H94W 50" Rear Projection...
Old zenith 36"
Bad CRT (the picture tube) they fail on the many of the zenith sets.
Jul 26, 2008 | Zenith C27A24T 27" TV
Tube set zenith tv
This is very typical of a Zenith set.Your picture tube will have to be replaced.One of your 3 primary colors (red,green,&blue) have turned off leaving you with the color of the dominant color.I would heave it.
Feb 10, 2008 | Televison & Video
Bad picture color. red LED blinks 5 times. Replace picture tube?
Definitely bad picture tube==not worth fixing......T.
Oct 11, 2007 | Sony KV-36FS16 36" TV
IQC50H94W
The convergence IC's should be the first suspect in any convergence issue. Hopefully you can place the magnets back where they were or you will have that alignment to deal with first.
Apr 09, 2007 | Zenith IQC50H95W 50" Rear Projection...
Open Questions:
See all Zenith IQC50H94W 50" Rear Projection Television Questions
Zenith IQC50H94W 50" Rear Projection Television Logo
62 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
