Question about Amana AP099R Air Conditioner
Amana AP095R no longer works, has a blinking light & beeps
I have been using this AC all summer up until yesterday when I turned it off & tried to turn it on again, I got a beeping sound with a flashing red light above the on/off switch. I unplugged it, tried to re-set it but nothing, is there something I'm missing?
  • jffwlczk Oct 14, 2007
    Thank you for the reply, I had it unplugged since I had posted the
    problem, when I seen that you had responded, I plugged it in to count
    the flashes, but now its working again, go figure! Is there a site that
    I can log on to for the code if this should happen again? I did a
    search before finding this site, and there wasn't much available info
    in regards to this model.
    Thank you for you time
  • JoRo25 Jan 11, 2008
    I'm also having the problem with the blinking on the power button as well as t beeps. It beeps a totla of ten times then stops. I'm not sure what to do. I have an Amana APR095R.
    Problem Solver:
  • 18 Answers
Count The number of flashes that you are getting in between pauses, This is a code.   I will be glad to look up your code if you can count that for me. also i will need the model number.
Posted on Oct 13, 2007
  • Lee Harmon Oct 14, 2007
    Im cant find the codes on websites but when i go into work on monday ill be happy  to find a copy of them and send it to you via reply
  • anur_pt_is May 30, 2011
    On he back of the unit when the dehumidifier water collection bucket is full it auto shuts off. Solution unplug unit drain water out and replug in. This unit is suppose to dispose of it thru evaporation but at times cant keep up in high moisture times.
SOURCE:
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
May 24, 2015 | Sony SY-ICF-C414 Clock Radio
Well yesterday I tried an HDMI cable instead of the regular cable with the three colors it came with. Now I go back to the Three colored cable and Ot does not display anything nor does it make a sound. It...
When you're switching to a new or another TV other than the one that you're using or have swapped leads as you have described then you will need to reset the video settings on the PS3.
To do this turn the PS3 off so the red light is on. Hold down the power button on the PS3 until you hear a beep. Release the power button and press it again.
That should have reset the video settings so you will be able to set the video settings again on the other TV and access the PS3 menu to set it up again.
Regards.
Aug 16, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont display anything but a black screen through hdmi, tried holding in standby button but only ge t 1 beep before going to standby. i also tried component through av1, that gives a white flash...
Ok do not worry this may mean two things crached hard drive or a corrupted hard drive all you have to do is turn it on but let the red ligth be on turn it on do not remove your finger from the button until it go's off again turn it on again keep your finger until it makes a sound but still do not remover your finger untill it makes two sounds after eachouther take your finger of fast nou a screen will apear say restore sestem untill your ps3 works again it take 1-4 trys and if nothing happens you must format it.HOPE I WAS USEFULL PLZZ RATE ME AND IF THERE IS ANYTHING ELS EMAIL ME TO [email protected] I DO PS1,2,3,DVD PLAYERS AND PC sorry for my spelling i am only 13 BUT PLZZZ RATE ME
Nov 08, 2009 | Sony Playstation 3 (PS3) Console
My ps3 it goes green beeps twice then goes red and flashes on/off
you might be holding the power on button to long. you hold the power on button until it beeps to reset the video output. try turning it on by using your controller. just press the ps3 button and if the red light is on then it should come on.
Oct 14, 2009 | Sony Playstation 3 (PS3) Console
Computer not turning on
probably it is your operating system. try to recover your windows by using the recovery disc that came out with your e machine or find another widows to install but do not format the hard disk rather replace the existing one.
if you can't make it, please send me an email at [email protected] then i will help you step by step.
thanks
wonder
Sep 17, 2009 | E-Machines (308714) Motherboard
When I turn on the PS3 console an orange light blinks for a few seconds then the console turns off with the red light flashing
Try this:
With the system off, hold down the power button on your PS3 for 10 seconds. This should set everything to default settings. If that doesn't work, try holding it down until you hear the beep that sounds when the system turns on. Keep it held until you hear 2 more beeps, and release it instantly. A bunch of options should appear on the TV. Select option 3. It will ask to do it again, just keep going until it is finished. If it doesn't work after that, you need to send it Sony. If you have a warranty, you can take it back to where you got it from.
Aug 18, 2009 | Sony PlayStation® 3 (80GB) Console
Porsche Beeping and no disk image
Does it spin?
Is it beeping similar to any of these sounds: http://datacent.com/hard_drive_sounds.php ?
Nov 03, 2008 | LaCie F.A. Porsche (301177) Hard Drive
Amana AC
Hi, the aircondationer compressor was stuck , the thermal control open the red light on , you may call fixya authorized repair service near you you just enter zip code .
Jan 30, 2008 | Amana AP099R Air Conditioner
Red light blinks after beep
I look all over the net but could't find anything, until i found a site that said they
could show me how to fix any problem with my ps3. At first i was not so
sure about ordering the manual but i did, whats $5 plus i used paypal, but
long story short i fix my ps3, i recomend this site www.gameme.20fr.com
i hope this help you like it help me.
Jan 19, 2008 | Sony Playstation 3 (PS3) Console
Heating & Cooling Logo
1,116 people viewed this question
Top Amana Heating & Cooling Experts
Donni Steen
Bill Long
WatsHVAC
Level 1 Expert
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
