Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 error code F06
    President:
  • 331 Answers
Terry, here's the fault definition and the checks/repairs for it... F/06; Drive Motor Tachometer Error "The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes." Check/Repair; * Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU) * Check the Drive Motor * Check the MCU * Check the Wire Harness If you can next time, please provide the entire model number in your post so we can help a bit more. Kenmore doesn't actually manufacture anything, they purchase their units from manufacturers and slap the Kenmore label on them. The model number is located just inside the door on the frame of the unit.
Posted on Oct 03, 2007
SOURCE:
SOURCE: Error Code for Kenmore HE3
The "F" variables (F4-F16) are for electrical problems. You should select Pause/Cancel twice then select Drain/Spin if there is excessive water in the washer. Re-select cycle and press start. According to the manual, if the problem remains, call for service.
Posted on Dec 31, 2006
SOURCE: kenmore elite HE3 Error Code
In the article, on checking the drain pump, it recommends draining the wash drum. How do you do this if the door is locked and the buttons won't yield any results or unlock the door?
Posted on Jul 14, 2008
SOURCE: kenmore elite he3 front load
I had the same issue with a brand new wash. The issue I found was the installers installed the drain line too low. The drain line needs to be a minimum of 39" above the floor. Hope this helps -- Kent
Posted on Nov 11, 2008
JR JR
  • 116 Answers
SOURCE: Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Posted on Nov 30, 2008
Daniel S
  • 4323 Answers
SOURCE: F error code "kenmore top load" washer oasis he3
Hi
LF means Long Fill, this error flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change. Check whether water supply is connected and turned on. Make sure the hose is not blocked and hose screen is clear. If so make sure pressure hose connection to machine/motor control is fine. Also check the continuity of water inlet valve, use a multimeter to check the continuity. Hope this helps... Please post back if you need more information.
Daniel
Posted on Feb 16, 2011
Error Code 01 F06
Your fault is mentioned here.
An F06 fault code in a Whirlpool Duet washer (the Kenmore HE3/4t's are also made by Whirlpool) usually means a motor-related problem. It usually pops up when the drum won't rotate at all or only very sluggishly. Here's the excerpt from the Whirlpool Duet Service Manual on this:
http://fixitnow.com/wp/2008/10/28/whirlpool-duet-washer-with-an-f06-fault-code/
May 10, 2015 | Maytag Dryers
Tip
I have a Kenmore HE3, with an intermittent F06 error. It seemed like heavier...
This advice is for Kenmore Elite HE and Whirlpool Duet FRONT LOADER washing machines displaying the "F06" error code. The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 – is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
I hope this information is helpful.
on Nov 20, 2010 | Kenmore Elite 45986 Front Load Washer
What does f or f6 mean on a he3
The F06 error code on the HE3 elite is a tachometer error. Per the tech sheet, it says to check all connections and continuity between the MCU, CCU and Drive Motor. You would need a multimeter and be able perform an ohms test on the Motor, the Motor Control Unit, and the Central Control Unit as well. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks again Rick
Sep 24, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Our Kenmore HE3 washer errors f06 towards the end of the wash cycle, last 25-15minutes. Not every load.
F06 indicates a drive tach error. Remove all connectors, one at a time, from all control boards and replace back in position, being sure they are tight. Most of these faults are caused by poor connections, especially when they are intermittent.
Jan 12, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
What does the F06 error code on the Kenmore Elite HE3 washer mean?
Hi
Thanks for using FixYa. Error F06 in your whirlpool duet indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 27, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
F6????
The F06 error code on the HE3 elite is a tachometer error. Per the tech sheet, it says to check all connections and continuity between the MCU, CCU and Drive Motor. The tech sheet says normal reading is at 6 ohms.
Apr 18, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Flashing code F06, currently will not do anything
The F06 error is a drive motor tachometer error. This means the motor is not running or if it is then the tachometer circuit in the motor has failed. This error will be a failure of the motor or the motor control. both expensive and the motor being being the more difficult one try unplugging if for no less than 5 minutes to flush all codes... to see if it wasnt an intermitent problem. hope this helps......
Oct 24, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
F06 error
Check the drain pump. There may be something jammed it it, causing it to overload, and bringing up the fault code.
Oct 25, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
53 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
