Question about Sony Playstation 3 (PS3) Console
Help sir i have ps3 NTSC J now it is not coming picture power and cable is ok ps3 is working as normaly but dont have disply is it any software problem ?can you help me what i can do? thanks
    Problem Solver:
  • 7 Answers
U probably messed with the display setting....r u using a regular tv or HDTV....if u using HD make sure its on HD settings.. if thats not the case....then when was the last time it worked fine.
Posted on Oct 03, 2007
SOURCE:
The play stion is coming on but its sayin no signal on the tv
sir you better check your audio video cable,, maybe your audio video cable have a lost connection... if your a/v cables ok and work fine.. next check AV MULTI-OUT port on the back of the PS3 system make sure that is properly connected to your monitor screen... or visit the link below for more info on how to troubleshoot you ps3..
http://us.playstation.com/support/answer/index.htm?a_id=282
if this help you please rate me thank you sir...
Jun 11, 2011 | Sony Playstation 3 (PS3) Console
PS3 turns but DON'T SHOW UP ON A TV. Hey there. 1-2 weeks ago i was to my friend with my ps3 and there we turn the console on with an HDMI cable. it worked well. Then i came home and when i turn my ps3...
ok with the power button turned off press and hold the power button you will here one beep and then two beeps and then release and look at your tv and there you go.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 30, 2011 | Sony Playstation 3 (PS3) Console
Sirs: I have a new Sanyo 42" TV. We are on
Hello
If picture and sound is ok, and there is no colour, your push have sometimes made its system changed. I don't know from where you are, and to which country you belongs. Anyway I'll give you one solution.
Your Sanyo Tv may have multisystem compactable. There are mainly three systems in transmision of TV signals, called PAL [Phase Alternating Line], SECAM [Sequential colour and mamory] and NTSC [National Telivision System Committee]. Most of the europian countries have transmitters with SECAM and NTSC. I belongs to India, and here we have PAL BG system.
If the system has changed in the tv, the picture will not have chroma information, ie ,colour information, and black and white picture will be the result. You just do one thing. Just get into the Menu of your TV, according to its documantaion that you have, and go to the system menu, and make it "AUTO". This will solve your problem. Ok.
Nov 24, 2010 | Sanyo DS31520 31" TV
PAL PS3 NTSC HDTV, HDMI Cables don't work, WHY?
I have the same problem. I get the "Mode Not Supported" message on my Samsung pn50b860 when I try to run the PS3 through the HDMI. Any solutions/suggestions yet?
Jan 06, 2010 | Sony Playstation 3 (PS3) Console
When i turn it on the light turn greens than no picture comes up
check the cables normaly its the red or yellow cables that connectto the screen wich do that.
if its connected so try to touch it or spin the bable a bit.
Jul 21, 2009 | Sony Playstation 3 (PS3) Console
PS3 image keeps scrolling and is in black and white
I am an Australian ( 240v) and I took my PS3 to the Caribbean (110v - same as the US) and it worked fine as far as power concerned. However as I had the PS3 set to work on my TV back home (PAL) when I took it over there & plugged it in (NTSC) I had a similar problem. I fixed it like this: when the PS3 is turned off hold down the power button for 15-30 seconds it will reset the PS3's settings to defult and it should work on the system that it's connected to. Hope it helps
Jul 02, 2009 | Sony PlayStation® 3 (80GB) Console
My 80gb playstation stops as the oppening screen starts up. It will hold at this screen. Sound and picture is on and then it won't shut down with out holding the on/off button for 10sec. Why won't it start...
could be an up date problem need to delete it by
turn on the ps3 so its on the red light then hold down the eject botton and power at the same time
the ps3 should come on then go off
repeate agen and it should come up on the screen with options ( this is maintence mode)
reset system if that dont work reset the other options
may not work if ur usin hdmi cable may need normaly cable
and can delete game saves ect
Jun 09, 2009 | Sony Playstation 3 (PS3) Console
European PS3 now in the U.S.
You need a TV that supports PAL.
Or, if you want to keep your TV, you need a PAL to NTSC converter.
Here's a list of converters.
Good luck with your PS3.
Aug 19, 2008 | Sony Playstation 3 (PS3) Console
Hooking up ps3
Check system in TV Format Setup:
NTSC or PAL N
Dec 28, 2007 | Onkyo TX-SR803 Receiver
Problem help
ok bud, here's what id do from one gamer to another. dont have a ps3 though, but a ps2 and an xbox. it could be one of two things. the 1st, you could have your AV jacks, red white and yellow connected to the wrong colors, this would cause no picture to show up. make sure they are the same if that doesnt do it, than unfortunatly in my opinion you may need to see if its still under warranty. since something is either fried or the cables could be threaded wrong or something insdie the console, and you cant gain access to that unless you take out all the screws, and i did that for my ps2 take my advice dont do it. if that isnt it, than I dont know, but i thought id give it a shot :)
Sep 13, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
43 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
