Question about GE XL1800 1100 Watts Microwave Oven
GE XL1800 JVM1870SF02
My microwave turntable does not work and may turn about a half a turn then stop. If I remove the glass plate, it works fine. I don't see any obstructions and nothing seems to be holding it back (friction, etc). If it is the motor, is it easy to replace and are there any instructions available? Thanks!
  • GIP7 Dec 24, 2007
    The turntable turns, but when you put something on the table to heat it will not turn. I have changes the rollers and it still will not turn when you put something on it.
Remove the 7 screw around the perimeter of the base. Lift back of plate up over clips and remove there are wire attached to the base for your night time lights and the motor. remove the two screws holding the motor in and the plug. When reinstalling ensure you line up the flat side of the motor with the rotating plate key.
Posted on Nov 03, 2007
I have the same problem on a Jenn Air. Did you get an answer?
Posted on Oct 03, 2007
SOURCE:
The motor for the turntable is working fine, but the connection to the glass plate is so poor that it usually slips instead of turning the plate. This happens if anything larger than a glass of water is...
The glass plate has to be correctly seated on the drive spindle before you can have any hope of reliable rotation. Place the plate on the spindle and spin it gently until it seats.
Feb 14, 2018 | GE WES1384SMSS Stainless Steel 1000 Watts...
What are the dimension of XL1800 JVM1870SF02?
2.0 Cu
1100 watts
36"
If you want more info, on exact measurements, then you can copy and paste this link in your internet address bar under a new tab:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=240268_jvm3670sk_c3.pdf
Apr 17, 2010 | GE XL1800 1100 Watts Microwave Oven
GE JVM1870SF02 - not heating up anything!!
I had the same problem with mine, and discovered, somehow, that when I manually turned on the "vent fan", the microwave worked fine. A bit of a pain, but it heated up the food when it hadn't been prior to the vent fan being on. Can't understand why it solved it, but it's been working like that for about a year now. When I forget to turn on the vent fan though, the food is just as cold as when I put it in.
Jul 28, 2008 | GE XL1800 1100 Watts Microwave Oven
My ge profile spacemaker xl1800 turntable stopped it turns once in a while. What do I need to replace. Where can I find the part number?
It's probably a bad turntable motor or coupler.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
GE Spacemaker XL1800 Microwave
Your turntable motor is shot. It's simple to remove and replace. you don't even have to take the microwave out of the shelf. To remove it take out seven screw around the perimeter of the bottom. Lift up on back of bottom to get over clips on the back. Remove the two screws holding the motor in and detach the plug. Find a electrical repair shop for you make pick it up and replace it. When replacing it take out plate and hold plate key down and align flat side of shaft on motor with the plate key.
Nov 30, 2006 | Samsung MW1030WA Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
388 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
