Question about Kenmore 54701 Dehumidifier
Kenmore 54701 everything works except I think the fan motor is bad, should the fan start as soon as the compressor does
Yes, the fan motor should come on when you start the unit.
I just came from my basement where i had the same problem.  My fan was not working- it was noisy at first, then it stopped working.  it seems the motor has some play in it and came out of the electromagnetic housing that should make it spin.  once it was slightly out , it no longer spinned.   I took it apart, and then reassembled it nice and tight.  there is still some play, but it is working great.  If it happens again i may try to get a replacement motor.
Posted on Oct 23, 2007
Fan stopped running but it sounds like the compressor is still trying to operate.
Eather the fan motor is going bad or the cap is try changing the cap first, if not the motor.
Jul 17, 2010 | Kenmore 54701 Dehumidifier
Motor makes noise
The compressor is a mechanical pump that will be loud...plus the fan has to move air to make it work correctly...not much you can do about it...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Feb 15, 2010 | Kenmore 54701 Dehumidifier
I have a Kenmore 54701 Dehumidifer that quit working is there any thing to look for or just throw it out and buy a new one
Is it not powering at all? Remove cabinet and check glass fuse on power supply board
Is it running but no water?
Check to see if fan is blowing; if not then thermosenser on fan motor blown
Fan and compressor running but no water? Maybe the room is already dry; if not than probably have coolant leak - not worth fixing
Dec 04, 2009 | Kenmore 54701 Dehumidifier
Kenmore 54701 (70 pt) dehumidifier is not prerforming properly
could be a bad humidistat or a bad PTC relay on the compressor, check for voltage going to compressor, and check neutral continuity, if there is both then you have a bad compressor, check warranty on comp replacement, if no voltage then the humidistat is probably bad
Jun 13, 2009 | Kenmore 54701 Dehumidifier
Kenmore 54701 (70 pt) dehumidifier will not power on.
This unit has had a lot of problems. It has come up in other forums. The fan motor is thermally protected. Could be the printed circuit board is bad. Check out this forum:
http://forum.doityourself.com/humidifiers-dehumidifiers/177549-kenmore-dehumidifier-fan-stopped.html
May 04, 2009 | Kenmore 54701 Dehumidifier
KENMORE 70 PINT DEHUMIDIFIER
4681A20040R is the fan part #. Bought one on e-bay. Fixed the same problem.
Aug 18, 2008 | Kenmore 54701 Dehumidifier
Dehumidifier not dehumidifying ...
Save the old one for parts if you get the same new one but I def. don't reccomend buying this unit again. The reviews are bad. The fan is not covered under the warranty except first year or extented warranty. I spoke with Kenmore & Sears about this to see if coverd under 5 yr. Only compressor,tubing & refrigeration system(see inside of front cover for warranty info.)
Sound more like a sensor/circuit board problem to me since fan is turning. I think the signal determins which setting fan needs via sensor assembly to run. I could be wrong. Justa thought.
Can you def. hear the compressor come on. You can look through grill to see fan spin & the compressor makes a clank/clunking noise/ The fan & compressor should turn same time. Good luck! If you got any info. on my fan problem & you have update or fixed your problem I ccould use some help. Check post for my problem.. Thanks! panfan1
Aug 13, 2007 | Kenmore 54701 Dehumidifier
Kenmore 54701 Dehumidifier Logo
368 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
